JDM B16 SWAP MAP Sensor
The JDM B16 has a map sensor on the throttle body.
Also there is a firewall map sensor on the EG.
I'm using the JDM b16 engine wiring harness connected to a P30 ecu.
Using the stock chassis harness. I just extended the jdm b16 harness.
Anyways I'm getting a Code 5, MAP sensor. I don't know which one to use.
The firewall or the one that came on the throttle body.
Re: JDM B16 SWAP MAP Sensor (dc2doi)
i this might help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">if you are switching from a motor with a firewall mount map sensor, to one with a tb map sensor then.
remove firewall mount map sensor.
take plug from firewall mount map sensor and plug it up to throttle body mount (it will reach)
done.</TD></TR></TABLE>
Re: JDM B16 SWAP MAP Sensor (crazyguy)
i origonally had a tb mount map sensor and switched to firewall map sensor(thats what came with motor) and i like the looks better
da9blk1
01-16-2008 05:04 AM
Brian Hinson
13
06-24-2006 04:05 PM
civichatch67
09-21-2005 10:11 AM
