map sensor codes and 3000 rpm rev limiter
i got a 95 civic ex with a 95 dx block and a 2000 ex head on it. it has two codes for the map sensor 3 and 5 i check the computer, the wiring, the map sensor they were all good. even changed the map sensor to a 2000 ex map sensor and once it warms up it has 3000 rpm rev limiter and starts burning gas real bad please help if you know anything thanks
Cool Cool Island Breezes. BOY-EE
Re: (what1118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what1118 »</TD></TR><TR><TD CLASS="quote">yea but people do it all the time </TD></TR></TABLE>
Wheres my titleeeee!
Re: map sensor codes and 3000 rpm rev limiter (what1118)
Thats what happened to my car when i swapped it. Make sure u have the right ECU also. Check TPS...
Banned
Re: map sensor codes and 3000 rpm rev limiter (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">are the map and tps plugs switched around? This happens a lot. </TD></TR></TABLE>
x2??
x2??
Re: map sensor codes and 3000 rpm rev limiter (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer »</TD></TR><TR><TD CLASS="quote">
x2??</TD></TR></TABLE>
The MAP and TPS sensors are both 3-wire plugs that are close togather and stem from the same area on the wiring harness. They can sometimes be confused.
what1118
12-12-2007 03:47 PM
what1118
11
12-10-2007 04:53 PM
Archie_G
10-21-2004 05:46 PM
