map sensor codes and 3000 rpm rev limiter
i got a 95 civic ex with a 95 dx block and a 2000 ex head on it. it has two codes for the map sensor 3 and 5 i check the computer, the wiring, the map sensor they were all good. even changed the map sensor to a 2000 ex map sensor and once it warms up it has 3000 rpm rev limiter and starts burning gas real bad please help if you know anything thanks
Re: map sensor codes and 3000 rpm rev limiter (what1118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^sam »</TD></TR><TR><TD CLASS="quote">sounds like you are having some wiring problem. </TD></TR></TABLE>
huh, NO!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what1118 »</TD></TR><TR><TD CLASS="quote">i got a 95 civic ex with a 95 dx block and a 2000 ex head on it. it has two codes for the map sensor 3 and 5 i check the computer, the wiring, the map sensor they were all good. even changed the map sensor to a 2000 ex map sensor and once it warms up it has 3000 rpm rev limiter and starts burning gas real bad please help if you know anything thanks </TD></TR></TABLE>
try resetting your ecu, if not then you should look into a vaccuum leak. code 3 is a bad sensor, and code 5 is a vaccuum leak.
huh, NO!
Re: map sensor codes and 3000 rpm rev limiter (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
huh, NO!
ok mr. smartpants just my 2cent
huh, NO!
Re: map sensor codes and 3000 rpm rev limiter (VRD^sam)
ok mr. smartpants just my 2cent </TD></TR></TABLE>
look i'm not here to argue, just trying to set the fact straight. don't want to send the op on a wild goose chase.
look i'm not here to argue, just trying to set the fact straight. don't want to send the op on a wild goose chase. </TD></TR></TABLE>
just my 2cent young grasshopper calm down
What type of ECU are you using? You do any wiring recently? Did this problem just start out of the blue?
i did have a vafc in there but took it out all the wiring is good i checked it wit a voltmeter. i have a p28 sensor good, wiring is good,computer is good, have vacum in the map sensor hole im stumped
Re: (what1118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what1118 »</TD></TR><TR><TD CLASS="quote">how do you reset ur ecu unplug it? ur jus disconnect the battery? cause i have done both of those</TD></TR></TABLE>
unplug the battery for about 5 min (give or take). being that you have tried those, then i would say you have a sensor problem. given that you spent sometime looking at all the vacuum hoses to make sure there is no leaks.
code 3 and 5 are simple fixes.
code 3 is a faulty sensor
code 5 is usually a leak.
if you have a voltage meter, you can go ahead and test the sensor.
under a light laod the sensor should read 1v or slightly lower. 2.5 - 2.75 if under a heavy load.
also, you haven't played with the hose to sensor? common mistakes are hook the hose to the wrong side of the throttle body and mix match wire harness from TP sensor.
Re: (what1118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what1118 »</TD></TR><TR><TD CLASS="quote">wat hose are you talking about?</TD></TR></TABLE>
oh, nevermind. you have a 95 ex, so the map should be mounted on the throttle body. sorry, i have a 93 civic hatch and i forget that 93 and prior have map sensors mounted on the firewall and not on the throttle body. LOL
what1118
12
12-17-2007 07:12 PM
what1118
12-12-2007 03:47 PM
Archie_G
10-21-2004 05:46 PM
