Map Sensor Code... I need help SEARCHED
* B A N N E D *
my y7 in an EF is throwing the map sensor (code 3) ive looked for the troubleshooting write up on it, but no luck, ive changed out the map sensor but still have nothing. any help is appreciated. thanks
Re: Map Sensor Code... I need help SEARCHED (nicko360)
Check the wiring and connectors for the sensor in the engine bay and at the ECU, as see if they are broken.
* B A N N E D *
Re: Map Sensor Code... I need help SEARCHED (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">Check the wiring and connectors for the sensor in the engine bay and at the ECU, as see if they are broken.</TD></TR></TABLE>
figured it out... there was a cut wire at the ECU
jus_spooln_wicha
06-13-2007 12:04 PM
krz6jdm
02-21-2006 01:36 AM
