MAP sensor code 3 help (solved)
Old Jun 15, 2015 | 12:03 PM
Bswapped's Avatar
Default MAP sensor code 3 help (solved)
Hey I've got a code 3 that comes and goes, yesterday i cold started the car it had no check engine light but when I would touch the map sensor plug the slightest touch would make the car idle rougher and at times almost make the car die.
I noticed that once the check engine light was on it sounded like the intake started sucking more air in. With the light on i could also wiggle the plug around and it wouldn't effect the idle and i could even unplug the MAP completely and it would still not effect the idle.
So once the MAP code 3 is triggered does the ecu cause the intake to suck more air?
Also I've replaced the MAP sensor still having this issue
Old Jun 15, 2015 | 12:38 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default re: MAP sensor code 3 help (solved)
When the MAP sensor code is thrown, the ECU just starts acting like it isn't there, so of course it wouldn't matter if you unplugged it. If touching the plug causes the code to throw, and replacing the sensor didn't help, then you have a problem in your wiring, probably in the socket itself. Wires and connectors get old. They rust. Connection quality deteriorates. Stuff like this happens.
You can get a http://www.ebay.com/itm/like/201139109091?lpid=82&chn=ps for cheap. Just cut off the old one, solder and heat shring in the new one, and you're done. 15, maybe 20 minutes of work.
Old Jun 15, 2015 | 03:22 PM
Former User's Avatar
A new connector sounds like it will do the trick.
Old Jun 15, 2015 | 05:53 PM
Bswapped's Avatar
I ordered a new connector plug i went out and inspected the wires and the middle wire right were it goes into the plug is about in half. I bet that's my issue. Got a brand new pig tail on order tho. Hopefully this is all my issue is. I've done a lot of fixing on this car since I've owned and have learned a lot thru forms and othe social media.
Thanks guy I appreciate your help
Old Jun 15, 2015 | 05:55 PM
Bswapped's Avatar
Originally Posted by NotARaCist
When the MAP sensor code is thrown, the ECU just starts acting like it isn't there, so of course it wouldn't matter if you unplugged it..
Thank you I was curious if the ecu was doing that or not it makes since
Old Jun 20, 2015 | 02:22 PM
Bswapped's Avatar
Alright i replaced my MAP sensor plug this morning with the new plug that came in the mail yesterday and drove it about a 100mile round trip and no check engine light came on so is say that way my issue
chucky86
Oct 13, 2011 02:46 PM
oakman513
Jul 24, 2011 09:31 AM
92ehatch
16
Feb 19, 2007 11:41 PM
Tex Blackwell
Apr 13, 2005 04:03 PM
chrysler kid
Sep 28, 2004 07:24 PM
