map sensor problem!!!wtf
Old Sep 3, 2006 | 07:57 PM
jay-d-em's Avatar
Default map sensor problem!!!wtf
ok guys i need help. today my integra was running fine, it was leaking anit- freeze from the bottom hose so i replaced it since it was old. problem fixed. now i fill my car back up with antifreeze get ready to go leave my garage and the car stalls. it takes a little while to turn on and then the cel comes on. its telling me its code 3, the map sensor. so i put another map sensor and its does the same thing. when i drive the car it kinda bogs when i take off. anybody have an idea what this is? could it be my intake gasket?
Old Sep 6, 2006 | 06:51 PM
jay-d-em's Avatar
Default Re: map sensor problem!!!wtf (jay-d-em)
i put another map sensor and now the cel is off. but sometimes the car stutters when i take off. could this be a vacum leak?
Old Sep 6, 2006 | 07:46 PM
unknown0001's Avatar
if you changed the map sensor and it went away it was the map sensor having a problem calculating the mas volume of air entering the throttle body/intake manifold.
If you start driving and it bogs, check for any vacuum leaks and make sure the map sensor line is hooked up fine.
Old Sep 7, 2006 | 05:07 PM
jay-d-em's Avatar
Default Re: map sensor problem!!!wtf (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">if you changed the map sensor and it went away it was the map sensor having a problem calculating the mas volume of air entering the throttle body/intake manifold.
If you start driving and it bogs, check for any vacuum leaks and make sure the map sensor line is hooked up fine. </TD></TR></TABLE>
ok thanks.
didder
Dec 16, 2008 11:13 AM
Tyler Con
Oct 10, 2007 11:53 PM
dizzyek
May 17, 2006 09:38 AM
