Making the connection?
Electrician
Clean out the hardline with a wire brush, it looks kind of flithy in there. Pop it in and start threading it. BECAREFUL not to cross thread or strip any of the threads.
you would have to screw in the black metel has consists of two(2) bolts that i think are 12mm and the put the hard line in the black rubber then bleed your clutch
Re: (iiiskipiii)
up, I can't see how that hose would connect to the hard wire..... i cant rotate the fitting without rotating the hose....
Edit: nvm figured it out
