Making the connection?
Anyone have any idea how these two fittings go together? Do they just pop in and I'm being a pussy?
https://img.photobucket.com/albums/v...2/DSC00031.jpg |
Re: Making the connection? (spyderracing32)
are you taking about the hard line, or the wiring plug?
Re: Making the connection? (jolt-tsp)
hardline
shouldn't it actually pop in, and then screw in?
they screw together
Clean out the hardline with a wire brush, it looks kind of flithy in there. Pop it in and start threading it. BECAREFUL not to cross thread or strip any of the threads.
Re: (Dimi)
Ahh make sense now. Definitely clean those buggers. Should screw right together.
you would have to screw in the black metel has consists of two(2) bolts that i think are 12mm and the put the hard line in the black rubber then bleed your clutch
Re: (iiiskipiii)
up, I can't see how that hose would connect to the hard wire..... i cant rotate the fitting without rotating the hose....
Edit: nvm figured it out |
