main seal/ oil pump
main seal/ oil pump
on a d16y7 does the oil pump have a gasket or is it just a o ring??? we did a vtec head swap in it an blew out the crank seal an are gonna try an change the sealw/o taken off the pump but in case we have to we would like to no if its a gasket or oil pump? or ne suggestions on how to take it out an replace?
thanks
thanks
Re: main seal/ oil pump (civic2nr97)
on the y7 its just a seal aroung the crank nose. it would be extreamly hard to remove with out taking off the iol pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2nr97 »</TD></TR><TR><TD CLASS="quote">is the seal a standard size like could i go get a asortment off o rings?</TD></TR></TABLE>
No its a seal you have to buy. make sure you lube it before you pound it in
Chargerhemi06
12-04-2014 05:43 PM
the.hamburglar
07-10-2006 10:01 PM
