LCA Arm Bolt
Old Jul 1, 2004 | 07:26 PM
smoke3's Avatar
Default LCA Arm Bolt
I am having problems with my lca bolt (the one that goes threw the strut and lca.
does anyone know the part number for this bolt.
when i checked the http://www.acuraautomotiveparts.org i came up with two differnt bolts. im nto sure which one i need.
http://www.acuraautomotivepart...0.gif
bolt number 19
or
http://www.acuraautomotivepart...9.gif
bolt number 34 or 35
thanks.
Old Jul 1, 2004 | 07:43 PM
IVI's Avatar
IVI
Default Re: LCA Arm Bolt (smoke3)
bolt 19. u can goto ur local dealership, its only about 8 bucks.
Old Jul 1, 2004 | 07:49 PM
smoke3's Avatar
Default Re: LCA Arm Bolt (IVI)
thanks
Old Jul 1, 2004 | 08:48 PM
Airmax55555's Avatar
or you can do what i did when my bolt broke and go to a parts store and buy a 3/8 bolt ( i think thats the right size) for a dollar just make sure its a high graded bolt
Old Jul 1, 2004 | 09:16 PM
patmcd's Avatar
Default Re: LCA Arm Bolt (Airmax55555)
I do believe that you need grade 8 bolts for that type of application.
Old Jul 2, 2004 | 12:48 AM
3.504's Avatar
Default Re: LCA Arm Bolt (patmcd)
i'd go w/ the honda lower damping fork self locking bolt before i went w/ hardware store grade 8. sure they're the same grade, but the hardware store bolt doesn't have the ribs or the nylon self locking threads. it is an 8 dollar part, but i'd rather have it and torque it to 47lb/ft before i'd use something not meant for the car... seems kinda un-safe for a suspension part to me.
Old Jul 2, 2004 | 02:23 AM
JFG Kevin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airmax55555 &raquo;</TD></TR><TR><TD CLASS="quote">or you can do what i did when my bolt broke and go to a parts store and buy a 3/8 bolt ( i think thats the right size) for a dollar just make sure its a high graded bolt</TD></TR></TABLE>
dont' go standard...got mettric....stay in inport bolt size........i just took off my bolt too...can't do it by hand...got to be shot out with air gun......good thing my friend owns a shop..
Old Jul 2, 2004 | 11:08 AM
smoke3's Avatar
y would i need 8 bolts. i only need two one for each side. the other bolts are ok im just replacing my strut?? please explain
Old Jul 2, 2004 | 12:03 PM
3.504's Avatar
they're talking about a grade 8 bolt, its a type of bolt. and 1 bolt and nut from honda is a little over 8 dollars for each side.
Old Jul 2, 2004 | 02:21 PM
fergy016's Avatar
Default Re: LCA Arm Bolt (3.504)
a grade 8 bolt can handle more weight then a cheaper silver harware store bolt. don't skimp on those bolts, there is a lot riding on them.
Old Jul 2, 2004 | 03:39 PM
smoke3's Avatar
ok so what size 8 grade do i need
Old Jul 2, 2004 | 03:48 PM
smoke3's Avatar
Default Re: (smoke3)
Can some one findme a site that sells the bushing that i need. for that bolt. ty
Old Jul 2, 2004 | 04:18 PM
smoke3's Avatar
so should i stay stock or buy a 8 grade bolt ???
Old Jul 2, 2004 | 04:40 PM
3.504's Avatar
energy suspension sells that bushing, but i believe you have to buy the whole kit, the bushing is 20.00 from honda
poolpool8
Apr 1, 2017 09:12 PM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
flip b18b
Jun 28, 2004 10:31 PM
Matt B
Apr 20, 2003 07:12 PM
rasta420
Jul 24, 2002 12:32 PM
