LS VTEC or B20 VTEC?
Old Mar 24, 2006 | 05:30 AM
hondachris1994's Avatar
Default LS VTEC or B20 VTEC?
Which would b the better motor to build? Im planning on doin 1 or the other but wanted more feedback from ppl who has done these builds...BTW Im planning on boreing 1 of these blocks .5mm over....From who ever has done these which 1 should I do?
Old Mar 24, 2006 | 05:31 AM
t0p_sh0tta's Avatar
Default Re: LS VTEC or B20 VTEC? (hondachris1994)
B20.
No replacement for displacement.
EDIT: make sure you build it right the first time. If you're going to half *** it stick with the LS/Vtec, as it might last a little longer.
Old Mar 24, 2006 | 05:44 AM
Default Re: LS VTEC or B20 VTEC? (t0p_sh0tta)
I will b building the whole bottom pistons, rods, bearings,etc...but which 1 is a better build?
Old Mar 24, 2006 | 06:03 AM
BTW if B20 which B20 block?
Old Mar 24, 2006 | 06:12 AM
civexturbo's Avatar
If you are going to build the motor for N/A use, I would go B20. Just make sure you get the B20B or B20Z block form the CR-V. The old B20 Prelude engines are not the same.
Old Mar 24, 2006 | 06:43 AM
Default Re: (civexturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civexturbo &raquo;</TD></TR><TR><TD CLASS="quote">If you are going to build the motor for N/A use, I would go B20. Just make sure you get the B20B or B20Z block form the CR-V.</TD></TR></TABLE> I have a b16 in my 94 hatch now would I b able to use my same motor mounts if I swap the b20?
Old Mar 24, 2006 | 07:18 AM
Default Re: (hondachris1994)
I got OBD1 b16a2 now. does it matter what yr B20 I use?
tony7626
Apr 6, 2009 06:12 PM
immrtaltchnq
Oct 21, 2008 07:46 AM
poppypizza
Nov 8, 2007 07:48 PM
civicsiluver
Jan 3, 2005 03:23 AM
