Low Compression Cyl2, P1300, P0301, P0303, Bad valve?
I must have jinxed myself posting a question about it earlier. Can someone confirm I'm on the right track?
CEL has been coming on more often lately. Always:
P1300, P0301, P0303
Used to come on rarely at low rpms with light throttle after the engine warmed up, now will likely come on a couple minutes into the start of a drive. Same codes always.
Results for dry compression test:
#1:200
#2:115
#3:193
#4:200
Wet:
#1:210
#2:125
#3:205
#4:215
Spark plug pictures attached, 1,2,3,4 is the order, I *think* they look ok. Could a problem with #2 be why I'm getting CEL misfires on #1 and #3?
Not leaking coolant, no smoke out the exhaust. I'm thinking I might have a valve issue, do you think I'm on the right track? Is next step leakdown test, valve adjustment? Both? Neither?
P1300, P0301, P0303
#1:200
#2:115
#3:193
#4:200
Wet:
#1:210
#2:125
#3:205
#4:215
Re: Low Compression Cyl2, P1300, P0301, P0303, Bad valve?
Number 2 is too low for a valve adjustment. Does it smoke at start up?
For the misfires, how old is the cap, rotor and wires?
Cap and rotor are about a year old. No "out of the ordinary" smoke on startup (ie its very light and clears in a minute)
leak down test. i had a similar issue did a leak down test showed a leaky intake valve but in fact my cam journal was eaten up where it wouldnt let the valve close all the way
Pull the head it is... gonna be about 2 weeks before I've got that kinda time so I'm going to do a leakdown test first, next weekend. Will update the thread in a week.
well my update is... during the week I realized I didn't do the compression test completely right, I did not have the throttle pressed all the way down when I did the test, so today I repeated the dry compression test with that step in place, and today I got different results:
#1:190
#2:150
#3:188
#4:165
I didn't get a leak tester from amazon b/c they're back ordered, I'm going to do a poor mans leak test by just hooking the hose from the compression test tool (sans valve) to the air compressor and see where I hear a leak
#1:190
#2:150
#3:188
#4:165
Seagull Management
It really doesn't even matter all that much if you did the test right or not. cylinder 2 is much lower than the other 3 cylinders. Could be a bent valve, broken/stuck ring, bent rod, blown headgasket, etc.
Although your crank sensor is shooting the misfire codes not because of missfire, it is because there is a slight discrepency with the rotation of the motor with both those cylinders being out, and the sensor notices this, expecially at idle or low load/thottle applications, so it shoots those codes simply cause the stumbling.
Just like everyone above says, it need to come apart.
98integralsB18
12-30-2010 05:17 AM
