little help guys
little help guys
How am i able to separate these two pieces? i have use alot of liquid wrench and the bolt came off no probably but how am i able to separate these two pieces? Is the threaded bolt area connected to the upper piece or the lower?
Now with this side while i was taking the nut off which was turning easily the bolt area was also spinning with the nut! The nut moved down the bolt shaft about 3 turns until the bolt starting to move with the nut. What could be happening here?
All help is appreciated.
Re: little help guys (vtec4lyfe)
For the upper ball joint, you can tap it with a smaller hammer. This will eventuall break the ball joint loose.
The same goes for the tie rod end. There seems to be rust around these pieces. Spray some WD-40 and let it sit as well.
m-
m-
Re: little help guys (beaneg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 »</TD></TR><TR><TD CLASS="quote">go to autozone or your local parts store and ask for a ball-joint seperator</TD></TR></TABLE>
Exactly! I believe depending on which Autozone you're at....they can "lend" you this tool for a small deposit that you will get back in FULL when you return it, minus like...sales tax or something.
Good luck man!
Good luck man!
Unceasing Measure
Re: little help guys (I Shot 50 Cent)
To keep that bolt from spinning, you'll want to use an air tool - preferably a gun. To separate the ball joints from the spindle, you grease the open end of the pickle fork - that's the rod with the tines on it that you pictured - insert it between the two and strike it very hard with a heavy hammer.
Done deal. Welcome to suspension
supermario680
16
02-08-2008 03:28 PM
jaydm ferio
01-22-2005 06:16 PM
