Big Brakes
Big Brakes
I am trying to upgrade my current setup but I still want to use 15" wheels. All of the Big brake kits I have seen so far require 17" wheels.
?s are
Whats the biggest size of rotors I can go in front & rear?
Should I use the stock civic master cylinder or could i upgrade to gsr master cylinder?
What is everyones setup on brakes?
Current Setup is:
GSR Front Brake Conversion
Rear Stock Drum brakes.....
Thanks!!!!
?s are
Current Setup is:
Thanks!!!!
Re: Big Brakes (jrockets)
just replace the rear drums with some disc brake set up, if you want to go with a bigger M/C, go with a 91 civic ex. this will bolt up to your lines and booster with no mods. you will upsizing from a 13/16 to a 15/16. which will be great for what you need.
Re: Big Brakes (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">you dont need big brakes unless you track the car and the stockers cant handle it anymore. a rear disk conversion and new pads/rotors and fluid should be more than enough for a street car. dont forget sticky tires as well.</TD></TR></TABLE>
Just search around for a set of good condition Integra rear disc brakes, install along with good pads...and you're good to go.
lastlude2k1se
10
01-17-2003 12:19 PM
Stryker908
11-21-2002 06:09 PM
