leaking oil? 00 civic si b16a2
hey guys,
ok so recently i put rmf narrow headers and exhuast on. but today i realized i had like oil spray idk how to discribe it but it was all over my block and by vtec silnoid and etc but it looks like there oil leaking out of the corner where the block and head meet. thats what it looks like. i was alil low on oil but i was rippin around alil so i was probally burning some oil. i cleaned the area for now since its late. tomoorow ill go get it checked out. its not a crazyy leak where in the morning i move the car and there oil spots. there are none. idk if its leaking but i just wanted to ask yous what u think. it looks like someone could of spilled alil oil while filling. ill have a picture up soon.
thanks guys
thanks guys
Re: leaking oil? 00 civic si b16a2
if its leaking by your vtec solenoid it might be ur vtec spool assembly gasket. the most common areas of the upper engine to leak oil are the head gasket, camshaft seal, and the vtec spool valve. common lower engine are the rear main seal and oil pan gasket.
What he said, Alot of times people see an oil leak and see oil sitting on the aluminum surface between the Head and Block and jump the gun freaking out thinking its a HeadGasket. Most of the time its one, several, or all of the following leaking and running down the engine:
-Distributor O-Ring
-Head Plug(Commonly called a cam seal, these are very common to leak on B-Series engines.
-Valve Cover Gasket
-VTEC Spool Gasket(For engines equipped with VTEC of Course)
-Actual Cam Seals behind the cam gears.
-4 other seals that will leak are the Spark Plug tube seals, they will not cause oil to form outside the engine but rather fill your spark plug tubes with oil. Generally pulling the plug wires out will tell you if some are leaking as they will have oil soaked on them.
To try and pin point the location it usually easiest to spray the engine block, head surface off with carb cleaner/brake cleaner and then go for a bit of a drive, then stop and see if you can see fresh oil leaking.
badm0j0
11
01-18-2007 06:52 PM
2k2silvertype-s
12-20-2002 07:04 AM
