Knock sensor causing a sluggish 3rd gear
Old 11-10-2006, 08:23 AM
brockscivic's Avatar
Default Knock sensor causing a sluggish 3rd gear
Ok, i finally got my knock sensor hooked up on my B16A OBD1 swap and since its been sluggish in spots going from about 2500 to 4000 rpms then it clears up. It has to be the knock sensor pulling timing for something. I just used crimp connectors and speaker wire until the radioshack gets in some 18 gauge sheilded wire and 50/50 solder. Could it be picked up voltage? or is does this have some kind of connection to my other problem of the knocking/rattle noise?
seen here: https://honda-tech.com/zerothread?id=1804018
Just wanting to make sure everythings gravy
Old 11-10-2006, 08:41 AM
JDAMC's Avatar
What kind of knocking/rattle noise? Like spark knocking?
Old 11-10-2006, 08:55 AM
f20bej1's Avatar
Default Re: (JDAMC)
what ecu r u runing
Old 11-10-2006, 09:09 AM
f20bej1's Avatar
Default Re: (f20b eg)
knock sensor is to detect any vibration on the engine it self it would cause i think for 3rd to be slugish
Old 11-10-2006, 11:08 AM
no its not spark knock at all...its a knock from something loose but its only audible in the inside of the car...not from the engine bay
but im running the P30 ecu
crxb16ftw
05-20-2007 10:31 PM
rice is nice
04-14-2005 08:46 PM
Jared
07-15-2003 07:29 PM
93NXLUDE
03-05-2003 06:32 PM
Quick Reply: Knock sensor causing a sluggish 3rd gear
