Knock sensor causing a sluggish 3rd gear
Ok, i finally got my knock sensor hooked up on my B16A OBD1 swap and since its been sluggish in spots going from about 2500 to 4000 rpms then it clears up. It has to be the knock sensor pulling timing for something. I just used crimp connectors and speaker wire until the radioshack gets in some 18 gauge sheilded wire and 50/50 solder. Could it be picked up voltage? or is does this have some kind of connection to my other problem of the knocking/rattle noise?
seen here: https://honda-tech.com/zerothread?id=1804018
Just wanting to make sure everythings gravy
Re: (f20b eg)
no its not spark knock at all...its a knock from something loose but its only audible in the inside of the car...not from the engine bay
but im running the P30 ecu
