just put in my 98 b18c.....code 22
95 si
engine : 98 jspec b18c
will my d16z6 vtec control unit (thingy) fit on the b18c?
a very knowledgable friend says yes. and i just wanted to know if anyone has done this
thanks
btw code 22 is no vtec pressure signal (jdm itr engine has no vtec pressure sensor)
thanks
edit im using a jun chipped p28 and a stock p28
Modified by yayaRl337 at 10:34 PM 5/17/2003
thanks
thanks
Re: just put in my 98 b18c.....code 22 (yayaRl337)
oh id like to add that i give Hmotorsonline an 8 out of 10 on the engine....it had a few problems, but no broken parts and it runs really good
you can either tap into your jdm vtec solenoid and run 2 wires, one for pressure switch and one for ground.
or you can get a USDM Vtec solenoid.
Re: just put in my 98 b18c.....code 22 (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas »</TD></TR><TR><TD CLASS="quote">you can either tap into your jdm vtec solenoid and run 2 wires, one for pressure switch and one for ground.
or you can get a USDM Vtec solenoid. </TD></TR></TABLE>
the vtec soleniod is one wire.....tap that wire and any ground to the pressure sensor plug?
drill the jdm vtec solenoid and run the wires and save yourself $150 thats what i did and it works fine
IHEARTMYHONDA91
21
06-29-2017 09:47 AM
excivicboy96
12
08-02-2007 09:29 AM
VTC_CiViC
11-17-2004 09:05 PM
Apex i ITR
10-21-2001 05:00 PM
