JDM Cluster question
Hello everyone,
I just purchased a JDM SIR cluster for my eg. B18C is going in. I pulled out the old cluster that did not have a tach. Here is what I found on the stock cluster. 2 sets of wires one for the left and one for the right side and also 2 middle wire(marked green and orange). The new cluster does not have the middle 2 plug in. what do i do. help. thanks
Re: JDM Cluster question (CivicHB93JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHB93JDM »</TD></TR><TR><TD CLASS="quote">Hello everyone,
I just purchased a JDM SIR cluster for my eg. B18C is going in. I pulled out the old cluster that did not have a tach. Here is what I found on the stock cluster. 2 sets of wires one for the left and one for the right side and also 2 middle wire(marked green and orange). The new cluster does not have the middle 2 plug in. what do i do. help. thanks</TD></TR></TABLE>
The new cluster doesn't have the little plug is what your saying? You can leave it out. When I swapped my DX (no tach) cluster out for an LX cluster, there were a few plugs the LX had I didn't, and a plug I had that the LX didn't, I just didn't plug them in, and theres no problems. The biggest thing is the longer 3-4" plugs. Just plug them in and test it, if something doesnt work right, then come back and ask again . Hope this helps!
Re: JDM Cluster question (EGtenchu)
yes it is the 2 little plugs. do you know what these plugs do? the 2 major plug does fit right. Just don't want to leave any lights off if I left the little plugs out. I'll try without it. thanks
The two middle plugs (green and yellow) are for cruise control (green) and SRS (yellow)....you do not have to plug them in and everything will work o.k. The JDM cluster does not have a SRS light or a Cruise Control light, but everything will still function correctly.
i ♥ my honda
Global Mod
Global Mod
Re: (b16pwrdeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16pwrdeg »</TD></TR><TR><TD CLASS="quote">The two middle plugs (green and yellow) are for cruise control (green) and SRS (yellow)....you do not have to plug them in and everything will work o.k. The JDM cluster does not have a SRS light or a Cruise Control light, but everything will still function correctly.</TD></TR></TABLE>
Exactly
green is cruse and yellow is srs
Exactly
blackbndt
10
11-28-2009 08:00 AM
949eg
05-29-2003 11:34 PM
