Which Cluster for my EJ1?
Going to be getting a new cluster for my 94 EX Coupe.. which cluster would look really good without breaking the bank? also I don't know a lot about cluster swaps and I don't want to spend loads on harnesses etc...
was thinking of going digital cluster but I heard they're all $200+.. so that won't happen unless someone knows a website that sells them cheaper.
Thanks.
Thanks.
Re: Which Cluster for my EJ1?
Just so you know, only another 92-95 EG cluster is going to be plug n play. A JDM SiR cluster is also plug and play, but it will read in KPH. Correctable, but you're into it for another $115 for a Yellow Box to convert KPH to MPH.
Yes, you can plug Integra clusters in, but fitment will be @ss without mods to the dash panel.
An S2K cluster swap is going require modification to even work, let alone fit.
The Spoon cluster will cost a lot more than $200 and it will read KPH.
Stack clusters will cost you a fortune and will need work on your end to get to function. Not worth it for a daily. A racing vehicle, yes, but not a daily.
fm
fm
