JDM 4 door cluster in a EG hatch?
Would a JDM 4 door clutster work in a hatch?/
there the 4 door indicated in there is the only difference i see.
Thankz
Thankz
Re: JDM 4 door cluster in a EG hatch? (Hatchcrap Ownz J0o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchcrap Ownz J0o »</TD></TR><TR><TD CLASS="quote">Yes it will. Plug in play.</TD></TR></TABLE>
Re: JDM 4 door cluster in a EG hatch? (Average Al)
Heh... to be a little bit more specific, it's the same as the EG6 3DR cluster (if you get the 5-spd EG9 cluster) except for the 4-door picture below the tach. That usually lights up when a door is open on the EG9 sedan, but of course it will not do anything in a hatchback or coupe if you put that cluster in, and the cluster will work just like any other EG cluster.
Re: JDM 4 door cluster in a EG hatch? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">Heh... to be a little bit more specific, it's the same as the EG6 3DR cluster (if you get the 5-spd EG9 cluster) except for the 4-door picture below the tach. That usually lights up when a door is open on the EG9 sedan, but of course it will not do anything in a hatchback or coupe if you put that cluster in, and the cluster will work just like any other EG cluster.</TD></TR></TABLE>
It does nothing in USDM sedans too. I've got one in my car. It would be interesting to see someone actually make it work though
Re: JDM 4 door cluster in a EG hatch? (Scissor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scissor »</TD></TR><TR><TD CLASS="quote">It does nothing in USDM sedans too. I've got one in my car. It would be interesting to see someone actually make it work though </TD></TR></TABLE>
just run wires from the door trigger to the correct pinout onthe cluster and it will work fine
Re: JDM 4 door cluster in a EG hatch? (Hybrid95CivicEX)
I will try that. Thanks.
edit: Anyone know where to find pinouts for the JDM cluster? My Helms manual is useless on this one...
95-EJ1
02-14-2006 02:16 PM
ninety9ex
07-09-2003 06:36 PM
