When you put the JDM EG6 Gauge cluster in a USDM Civic...
Re: When you put the JDM EG6 Gauge cluster in a USDM Civic... (ninety3EX)
don't know but is that cluster a direct fit swap to an eg civic? Plug in without mods at all?
d
d
Re: When you put the JDM EG6 Gauge cluster in a USDM Civic... (daver)
unless there is something wrong w/ the cluster then yeah it will show the door indicators.....i have a four door (EG9 cluster) and all four doors, and the trunk works too.
so yeah it should be just like your stock cluster but be jdm (amber)
Yeah the door light still works, and yes, it's plug and play, no mods necessary
Re: When you put the JDM EG6 Gauge cluster in a USDM Civic... (rodrez)
I don't know about this one. Change the bulb, if you're not too nervous about taking apart your cluster. I installed an EM1 cluster into my ej6. The door indicator light did not work!!! It was not the bulb either. Weird thing ............... I did an auto to manual conversion and added the cluster just for a better look. My light probably didn't work b/c it was activated with the plug that also indicated which gear the automatic tranny was in. I guess I'll never know for sure.......................
Re: When you put the JDM EG6 Gauge cluster in a USDM Civic... (Jswpstdoff)
For the 92-95 Civic, the EG6 cluster is plug and play, and on mine (as well as my friends hatches) the light works w/out mods
