ITR motor into ek civic
I did a mini me swap in my civic and it finally took a **** with a rod knock. So Im getting rid of the shitty sohc for a B18c5. Im trying to get more into the dohc now so i need a little help. I ordered the motor and it came with the ecu, engine harness, tranny, ps pump, ac, alternator, dizzy, intake manifold, cables, brackets and sensors. what else would i need to complete the swap? axles, shift linkages, what else?
any help is good. thanks
pm4nudes
Re: ITR motor into ek civic
itr 5 lug conversion
"dohc vtec" sticker
rear disc conversion
Throttle cable and mount
spoon calipers
ctr cluster
hasport mounts
custom midpipe
spoon n1 axleback
dc2 dual bend shaft
si t bracket
sri
camber kit
tein ss
ngk plugs
upper and lower radiator hoses
adjustable ball joints
its all there you just need to find it.
"dohc vtec" sticker
spoon calipers
ctr cluster
hasport mounts
custom midpipe
spoon n1 axleback
dc2 dual bend shaft
si t bracket
sri
camber kit
tein ss
ngk plugs
"dohc vtec" sticker
spoon calipers
ctr cluster
hasport mounts
custom midpipe
spoon n1 axleback
dc2 dual bend shaft
si t bracket
sri
camber kit
tein ss
ngk plugs
"dohc vtec" sticker
spoon calipers
ctr cluster
hasport mounts
custom midpipe
spoon n1 axleback
dc2 dual bend shaft
si t bracket
sri
camber kit
tein ss
ngk plugs
Landon, don't be stupid and waste your money on stupid crap like 5 lug and camber kits unless you need them. You have the list already rounded out. Arthas has a better list of things IMO.
P.s. For the love of god don't buy anything with an N1 attached to the name unless you are running over 8 lb of boost or want to be pulled over a lot.
shinchan
01-15-2003 03:34 PM
