ITR Header on 99-00 Si?
Re: ITR Header on 99-00 Si? (SW20 MR2)
it will bolt to the head fine, i think it will clear the oil pan too, b/c the b16 motor are jus alittle bit shorter then the b18c series motor.. correct me if i'm wrong..
jus f0 dekarayshunZ
Re: ITR Header on 99-00 Si? (Drunk-N-Munky)
it will fit but you will need to have your cat modified...the flanges are in different positions...so they need to cut the flange twist it and weld it back on
Re: ITR Header on 99-00 Si? (1.8L)
b18c and b16a have the same heads. so it will fit.
only b18b in the bseries motors are shorter.
wrong and wrong
but it will fit.
wrong and wrong
but it will fit.
ITR heads are same as B16 heads... both are PR3s (some) just the internals are different
B18b heads are shorter, therefore if you put a ITR header on a B18b it will hang lower
[Modified by Drunk-N-Munky, 12:59 AM 3/20/2003]
