itr header for dc
Old Jul 7, 2008 | 03:32 PM
san_diego_DC's Avatar
Default itr header for dc
im looking in to doing an exhaust on the teg and my plans are to go with a itr header and piping. no loud mufflers only stock tip. The only ting is, iv'e talked to a few tuner guys i know and 2 of the 3 siad that the flanges of the itr header wont bolt up to my stock ls. is this true and how can i get around it.
Old Jul 7, 2008 | 06:07 PM
hotrod99's Avatar
Default Re: itr header for dc (san_diego_DC)
it will fit,all b-series motors have the same bolt pattern
Old Jul 7, 2008 | 08:13 PM
posHonda's Avatar
Thats BS itll fit. Every B series motor has the same bolt pattern as hotrod99 said. I have a JDM ITR header on my gsr
Old Jul 8, 2008 | 07:22 AM
letsdrive's Avatar
im assuming youre talking about the JDM 4-1 ITR header w/ 2.5"OD collecter, right? of course it will bolt to the engine ,but they were right about it not fitting the other end.
you need a 2.5" cat cut and welded to fit in the space. the itr 4-1 is longer and has a bigger collector than stock. all b-pipes are the same, its the header and cat that change in configuraion accross the model and generation.
Old Jul 14, 2008 | 03:36 PM
3rdman's Avatar
Is there any issue with the ITR header fitting the LS motor height wise?
example the DC sports b16 99-00 si header will not fit on a GSR motor, its not tall enough.
but the ITR DC 4-1 with 2.5 collector will fit on the gsr motor no issues.
i blew my gsr motor up and have a 01 LS loaner and only have my DC ITR header. am i going to run into any issues with height? like the bottom hitting the oil pan like the b16 dc hits on the gsr motors?
Old Jul 14, 2008 | 03:50 PM
goota's Avatar
the lengths of the exhaust A-pipe and Cat changes only for 94-99 GS-R's. Otherwise all the USDM exhaust components are the same lengths/heights.
you will have a problem with the length, not height, if your GSR is not an 00-01.
smooz EK
Jul 17, 2006 12:18 AM
gold94accord
Feb 10, 2006 09:42 PM
integrasi
Jul 12, 2004 09:51 AM
LillDragun
Oct 22, 2002 04:10 PM
vtecmuscle
Sep 16, 2002 07:47 PM
