ITR in EG need help
ITR in EG need help
Basically we have a EG hatch swapping in a JDM ITR using a obd1 DX wiring harness. We had to clip the obd11 injectors off hte harness and add them to the DX harness same with this ALternator plug. We added wires for Knock, Vtec, Vtec pressure switch and ran the o2. Got a p28 had it rechipped for hte R Everything looks right but we arent getting vtec and the hatch is no where near pulling right.
jus f0 dekarayshunZ
Re: ITR in EG need help (CiRcUiTsi)
you have a jdm engine and a usdm ecu
your itr engine doesnt have a vtec PRESSURE sensor.....you said you ran a vtec pressure wire.....so you swapped the itr vtec control sensors out with somthing usdm?
Re: ITR in EG need help (yayaRl337)
also throwing code 6. Ill get you pics of what we wired. Asap
dont have my book so i cant find code 6 anyone?
Yes JDM type R and a rechipped p28 the wires we ran are the sensor right under the vtec solenoid. i thought that was the pressure sensor?
Re: ITR in EG need help (HavokB18)
if its a japanese engine you wont have a pressure sensor, and if your ecu is usdm, you wont get vtec.....should be a green plug for the pressure sensor, usually is
IHEARTMYHONDA91
21
06-29-2017 09:47 AM
Kirk@SyndromeAuto
01-14-2007 10:20 AM
PatrickGSR94
15
08-24-2003 12:51 PM
