installing a window regulator
well mine is all jacked up and i need to replace it so,
can someone post up a link for me. i would really appriciate it.
just take your door panel off and you can see what to do. takes like 20 min. very easy.
grab a rachet with a 10 mil. socket. i think that is all you need to change i out.
Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">just take your door panel off and you can see what to do. takes like 20 min. very easy.
grab a rachet with a 10 mil. socket. i think that is all you need to change i out. </TD></TR></TABLE>
yeah ive got the panel off and eveything, i just dont want to mess something up. i still have to remove the window though.
Re: (mistahmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mistahmac »</TD></TR><TR><TD CLASS="quote">you don't have to remove the window. just unbolt the it from the frame and then take out the out the whole reg/motor assembly.</TD></TR></TABLE>
really i didnt know that! I was told that i have to take it out because the regulator wont clear when it comes time ti take it off.
i ♥ my honda
Global Mod
Global Mod
Re: (diznikkajebus)
You have to unbolt the glass so you might as well pull it out. Pretty sure you have to anyway to get clearance for the removal. It's really easy though! Just pull the glass out at an angle and you will have no problems. It's like 5 10mm bolts or something.
Re: (vrrodri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE_HWD »</TD></TR><TR><TD CLASS="quote">where did you get your regulator from do the ones from ebay work good?</TD></TR></TABLE>
i got my regultor from honda! its like only 50 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri »</TD></TR><TR><TD CLASS="quote">some pics would help, mine is hard when trying to lower the window in the morning...</TD></TR></TABLE>
its possible that your motor is going out.
Re: installing a window regulator (diznikkajebus)
http://www.tegger.com/hondafaq...e.pdf
search there's a bunch of posts about it.
gato5254
04-02-2007 12:36 AM
