Radiator support, Does this need to be welded in?
Re: Radiator support, Does this need to be welded in? (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">Not at all, just throw it at your car, and it will stay.</TD></TR></TABLE>
Re: Radiator support, Does this need to be welded in? (highlandparkbigpimpn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highlandparkbigpimpn »</TD></TR><TR><TD CLASS="quote">yes it does need to be welded ! </TD></TR></TABLE>
thats what i thought too..cause i remember i asked a friend from a body shop before and he said yes.it needs to be welded
Modified by crazyguy at 1:09 PM 9/19/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audiko4 »</TD></TR><TR><TD CLASS="quote">
WTF?! are you guys serious? i really hope not, becuase if you were you have to be the most retarded people on here.
and if you are joking, please keep your jokes to yourself.
OP, you can have the radiator supprt welded on by a welder or a body shop.
you can also bolt it up yourself, which will save you money.
good luck!
good luck!
Re: Radiator support, Does this need to be welded in? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
Of course I'm serious. I did a JDM front end swap on my buddies 99 GS-R. We stood on the opposite side of the garage and got a running head start. We SLAMMED that **** on there hard enough to make it stay.
Of course I'm serious. I did a JDM front end swap on my buddies 99 GS-R. We stood on the opposite side of the garage and got a running head start. We SLAMMED that **** on there hard enough to make it stay.</TD></TR></TABLE>
ok, very funny. play time is over. lets get back to the topic.
ok, very funny. play time is over. lets get back to the topic.</TD></TR></TABLE>
Ok.
Yes. You do need to weld the rad support in. If you want to bolt it in, go a head. It will save money, but I would want the assurance of knowing it's not going anywhere.
Ok.
why would you even try to bolt it in? it is a sure thing that its gonna come lose in no time. i would do it the right way and weld it in that also make the car safe if you crash it its not to hard if you have a welder or even rent one, and know how to use it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highlandparkbigpimpn »</TD></TR><TR><TD CLASS="quote">why would you even try to bolt it in? it is a sure thing that its gonna come lose in no time. i would do it the right way and weld it in that also make the car safe if you crash it its not to hard if you have a welder or even rent one, and know how to use it </TD></TR></TABLE>
it wouldn't come loose if you use lock nuts!
duck tape a peice of string and some chewinggum will work
so yeah ti does need to be welded iun its just a few spot welds nothing terribe. had to do mine when the engine hoist broke and bent it... ooops
Re: (JDM-ish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-ish »</TD></TR><TR><TD CLASS="quote">how can you have over a thousand posts and not know if the radiator support is supposted to be welded on? </TD></TR></TABLE>
well some arnt... i know my s10 rad support is bolted on....
