94 si civic brake help
when i'm driving and come to a stop sign and i have to step on my brakes for a while, my brakes will slowly start to sink down, and if i let it go and do it agian, it'll keep on doing the same thing, what could be wrong?
Re: 94 si civic brake help (lilo_goki)
Is the brake fluid in the master cylinder low? If so, check for leaks around the master cylinder, front calipers, and rear wheel cylinder. Replace the leaking component and then thoroughly bleed the brakes.
If no leak is found, the master cylinder may be bad. Replace and bleed system.
Re: (lilo_goki)
If you can't find a leak then I should have suggested that you first try bleeding the system of air. If this doesn't fix the problem, then replace the master cylinder and rebleed.
mattbatson
10-23-2008 07:30 PM
MrIllegalX
08-24-2003 06:27 PM
