installed hid kit..only come on when brights are on
i already posted in the lighting forum but i can tell that it moves very slowly so i thoughtid just post in here to see if anyone can help with my problem
when i installed the hid kit( i dont care if u dont like plug and play hid kits) i had my high beam switch on and i didnt know because the night before i had them on. and when i turned on my hid's after i plugged themin to see how they looked they turned on when i switched them on but i didnt notice that the highbeam switch was on.
so ive been turning them on to show my dad and what not and then just now i pulled my car back and noticed that my high beam switch was on...i switched it off and now the lights wont come on unless they are on high beams.
any ideas so i can make them come on normally?
and my headlights are all off now one is higher than the other . how do i adjust them? i know u gotta mess with the little gear looking things on the lights but i turned them and they dont seem to do anything? is it because the headlights i got are cheap or something?
Re: installed hid kit..only come on when brights are on
Unless you got Bi-Xenons...
its not meant to be switched back and forth from high and low if that's how you hooked it up. if there just regular xenons than there only meant to be either high, or low beam
how many HID's did you hook up?
Is it plug and play sounds to me the high voltage (high Beam) And Low Voltage (low beam wires are mixed up happened to me when i redid the plugs to my headlight because they melted get a voltage light and turn your lights on see witch one is one the hit your brights should be able to find the high beam wire...
