HELP with a HID installation ....
i installed my HID kit on my eg6,,but before i install it..i can hhigbean my car..and i can see highbean and lowbean is on..but after i installed my HID kit..i can't turn both of them on the sametime..did i do something wrong on the installation???
Most likely you don't have a bi xenon kit which has a switch to flip down the shield to light up the bottom part of the headlights for highs.
You probly have alot of glare now and blinding on coming traffic cause your bulb is lighting up the whole housing.
You should look into retro fitting OEM HID projectors.
if bi-xenon, you should have two diodes for each headlight socket. switch them around and you're set
. this is simple otherwise if you don't have these diodes to turn the control on the headlight from positive to negative, you're gonna have to somehow find a wire diagram and do it manually via ground, negative, and positive wires of the stock socket....splicing and such..search it's on here and covered before.
if not bi-xenon i can't help you.
. this is simple otherwise if you don't have these diodes to turn the control on the headlight from positive to negative, you're gonna have to somehow find a wire diagram and do it manually via ground, negative, and positive wires of the stock socket....splicing and such..search it's on here and covered before.if not bi-xenon i can't help you.
i think mine was a bi-xenon but im not 100% sure i'll find out for you...
i also diagram the wire..and i connect pos to pos and neg to neg..
but not yet on the diodes for the headlight socket but i'll try
This is the HID kit i got ...and is a Xenon..none BI-xenon..so
please give me some details on how to fix this issue..i'll show picture of the hid kit on.tomorrow
yea..this is low bean only..because i have a projector..and low bean and high bean's are diffent slot....but the problem is..before when i install the HID kid..i turn on my headlight.....my highbean and low bean are turned on together.....but after i install the HID Kit..only can turn on either one at once.can 't turn on both at the same time....
you have an aftermarket headlight...OEM EG6 is dual filament...so it is working as it is supposed to...turn off low and turn on hi and vice versa because it is H4 positive switched...
i hope you understand what I mean...research if you have to...if will be another few pages to explain what that is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devani »</TD></TR><TR><TD CLASS="quote">you have an aftermarket headlight...OEM EG6 is dual filament...so it is working as it is supposed to...turn off low and turn on hi and vice versa because it is H4 positive switched...
you can get wiring harnesses (you should anyway with HID's) to route power from your battery to your headlights. if you get the right harness, it'll keep your low beams on even when your high beams are on. you want this for HID because frequently turning on/off your HIDs is bad... not that it really matters since PnP HID kits are POS's, esp ones with 8000K capsules!
do yourself a favor and do a HID retrofit!
do yourself a favor and do a HID retrofit![/QUOTE]
why??? i was thinking about that..but i dont want to expletive up the casing..for my headlight that's why.....
other thing..when i put the normal light i can high bean and low bean turned on at th e same time..even tho..i dont turn on the highbean..because the h4 got high and lowbean.... but after i install the HID kid..my h4 lowbean doesn't turn on..grr this is really pissin me off
thats weird,,show a pic of the bulb ..sometimes the plug from the bulb to the ballast is different( more wires )..post it,,,,ill show u how to install it,,i do retrofit fits n i even fix ballast,,,dont worry its a peace of cake,,its just hard to explain
H4 is not supposed to turn on low and hi at the same time in stock form....that means your wiring is not correct...
I am located 5 min from GWB...if you are close I can help you out....
I'm with devani, I don't understand how you were able to turn on both low and high beam at the same time with your aftermarket projectors, unless some custom re-wiring was done.
And if this custom re-wiring was done, you should still be able to have both the low beam HID kit on and the high beams on at the same time. So I don't understand why it's not working now.
But since you have aftermarket projectors, an HID projector retrofit should be fairly straight-forward with small projectors. I've seen write-ups of people who have done it.
The only catch is you can't use those bulbs from the HID kit with OEM HID projectors. You would need OEM D2S bulbs, and either an aftermarket-to-OEM D2 adapter harness on the ballast, or new ballasts with D2 plugs on it already.
I was able to when I had OEM housings and eBay projectors. IN order to have Hi and Lo beam on at the same time, you had to hold down the lever. So instead of releasing it after clicking to get high beam, you just hold it down and it'll keep both lights on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Genuine Rolla »</TD></TR><TR><TD CLASS="quote">I was able to when I had OEM housings and eBay projectors. IN order to have Hi and Lo beam on at the same time, you had to hold down the lever. So instead of releasing it after clicking to get high beam, you just hold it down and it'll keep both lights on. </TD></TR></TABLE>
yeah... if you do THAT, then of course you're sending power to both high and low beams...
FYI: i did a PnP --> retrofit (check my sig for write-up)
halogen projectors are garbage and give MAD hot spots (uneven light distribution).
also, those made in china 8000K capsules you got aren't gonna give you any good lumens for seeing the road. OEM 4300K capsules FTW!
i'm in bklyn NYC..if u drivin from GWB prolly like 25 minute or so.. but i don twant to waste your money by crossin the bridge or wat so eva..
h4 got high/low bean...they are not on the same time..
is hard to explain..let me try to take a picture of it...to show you guys..is really rare..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devani »</TD></TR><TR><TD CLASS="quote">H4 is not supposed to turn on low and hi at the same time in stock form....that means your wiring is not correct...
I am located 5 min from GWB...if you are close I can help you out....</TD></TR></TABLE>
that's a really nice write up..
but i'm scare it will mess up my headlight casing.that's why i dont wanna do that..
my highbrean and low bean aint on the same time..
i mean..my low bean from h1 and low bean from h4 is On the same time..
that's wat i want to do..when i turn on the headlight..both low bean is on the same time.... ....
EX-JAY
Mar 19, 2005 07:50 PM
