b20 in eg, mounting problems
ok so i got a b20 with gsr trans and i cant get it to sit in the engine bay level. the trans side if ike half a inch to a inch higher. any ideas would be helpful. could it maybe be my mounts. using b20 bracket with d series mount on driver side with the gsr mount on the trans. thought maybe using d series bracket on trans but there the same. any ideas?
Re: b20 in eg, mounting problems
its the driver side mount, u have to use any other b series mount then the b20, the one that has the 2 studs in it that bolts to the block, on some crvs the block sits lower cause of the intake mainfold
Seagull Management
I don't know if that CR-V T bracket works in a civic, '94 - '01 integra will though, other than that, was the car an automatic? the stock automatic pocket mount is angled up and will cause the transmission side to sit up to high.
well i know i have to use the b series manaul brackets in the front and rear of the transmission. ok so will the ls mounts work on the driver side to bring it up just a little
o and i know it has nothing to do with the t bracket because it isnt even on just the side mounts are on. guess ill try a b18 mount on the driver side
Seagull Management
You can use an LS mount, but I don't know that it will make a difference.
it might be the driver side mount though because it to different kinds of mounts put together, b20 on the block then the d series bolted to it. ill just try the one off my buddies 01 inegra ls. and what about my shift linkage do i use any b series linkage of gsr linkage since is a gsr trans
yeah you need a b series shift linkage i had the same problem in my ek the bracket on the b20 was too long i jus replaced it with a ls bracket from a 94 and up and its all level now......
blufke
07-23-2002 08:56 PM
