inner fender liner???
Old 10-18-2008, 10:34 AM
shaggsdb's Avatar
Default inner fender liner???
i have 1992 civic cx hatch. what purpose does the inner fender liner serve?? what would happen if they where removed??? also i heard if you removed them it allows heat in the engine bay to escape. is this true??? thanks
Old 10-18-2008, 10:55 AM
Frickr's Avatar
Default Re: inner fender liner??? (shaggsdb)
it keeps the junk from flying up all over your motor bay and in your door jams. removing it wont help with heat. if you are having problems with heat, then its going to take a lot more then pulling the liners out to help that problem. only time it needs to be removed is if your slammed and cant run with it on.
Old 10-18-2008, 10:59 AM
shaggsdb's Avatar
Default Re: inner fender liner??? (Frickr)
i dont have problem from heat, just one of my friends was trying to tell me that. the main reason i asked is cause mine are beat up from someone tryin to steal my car and my car is dropped and it rubs a little. i just wanted to make sure removing them wasnt gonna hurt anything. is there any areodynamic drawback from removing them??
Old 10-18-2008, 11:02 AM
ihrtjdmeg's Avatar
yup Frickr basically covered all the bases. If you want to slam your car and tuck some tires then you would remove it but other then that it helps from crap flying inside your engine bay.
Old 10-18-2008, 11:06 AM
shaggsdb's Avatar
Default Re: (ihrtjdmeg)
ok thanks both of you. i'm gonna take them off and go get replacements at the junkyard. is there any aero dynamic drawback in having them removed???
Old 10-18-2008, 05:48 PM
tigasin's Avatar
Default Re: (shaggsdb)
if your car is not slammed i advice you to put it back.i took out mine and now im having a problem on the wires that goes thru the door.(power windows and door locks)***** getting corroded coz it always got wet even though the rubber is there.
Old 10-18-2008, 05:55 PM
unsungfate's Avatar
Default Re: (tigasin)
also. it serves as road noise dampener..
Old 10-18-2008, 07:13 PM
shaggsdb's Avatar
tigasin-i have cx it doesnt have any power door locks or power window or power mirrors. is there any other wires that would be run through the door???
unsungfate- not really worried about road noise got a stereo for that
i plan on replacing them in about 2-3 weeks i just wanted to know for the time being would i be ok
Old 10-18-2008, 09:23 PM
Frickr's Avatar
other then things getting dirtier faster, a bunch of sand and stuff in various places in your motor bay, and door jams, and water splashing around i wouldnt worry about it to much. another option would be to take a mudflap off of a truck and cut to fit inside so it covers all the vitals and dont have a problem with rubbing no matter how low you are. also could be cheaper depending on the junkyard.
Old 10-18-2008, 10:18 PM
sintype's Avatar
my suggestion is keep it on there.
Old 10-18-2008, 11:17 PM
duefuss's Avatar
Default Re: (sintype)
WOW this guy is hard headed look dude noone has said its cool to roll with them off every one of us has said keep them on so keep em on or dont and learn the hard way......
Old 10-19-2008, 05:01 AM
tigasin's Avatar
yup,not familiar w/ non-power cars,but all i can think of is speaker wire.it's really better to put it back unless you want to collect dust,dirt and rust thru your door jams....
Old 10-19-2008, 07:50 AM
punkinbeck's Avatar
Keeps dirt, water, tar and rocks from ruining your fenders and door hinges.. I bought a hatch one time that came with some nasty z3 fenders and no inner fenders.. Mud would splash out the vents.. It was pretty awful..
Old 10-19-2008, 08:39 AM
shaggsdb's Avatar
ok thanks everyone i'm gonna leave them on till i can get to the junkyard to get some replacements
Old 10-19-2008, 03:12 PM
raidacaipo's Avatar
I say the only purpose for them is to protect yourself from theives.. the fender is where your hood latch cable runs through.. all they do it pull back the fender liner and stick their hand under the fender and pull the hood latch.. other then that its a good theif deterent.. but if you remove the inner liner I suggest you relocate your hood latch cable to the inside of the engine bay instead of the inside of the fender.
Old 10-19-2008, 03:25 PM
H-T White Ops
NOFX's Avatar
Default FV-QR
Open the door. Look in the front near the hinge to see if there are any wires.
I've seen cars that have been driven without fender liners. It's not just a little dirt that gets in there. Sand, rocks, mud, leaves, water. When you open the hood you'll see rocks and crap sitting all along the edge of the hood, all over the sides of the engine bay, in the door jambs, all the way down the sideskirts.
It just makes a huge mess.
Old 10-19-2008, 09:23 PM
raidacaipo's Avatar
how much are brand new fender liners?
Old 10-20-2008, 05:29 PM
punkinbeck's Avatar
Default Re: inner fender liner??? (raidacaipo)
I think i paid like 35 dollars a piece years ago.. Got them at the junk yard a couple months ago for 5 each
Old 10-26-2008, 07:56 PM
djmaxi1's Avatar
if you pull them off its just easier for the thieves to reach under and pull your hood (latch wire)....
your choice....
IMO...KEEP THEM ON!!!
Old 01-08-2009, 01:07 PM
SoulMate's Avatar
Hi, guys! I'm just bought an EM1 Civic Si. As I know there is no OEM inner REAR fender liner for Civics. But I have found some aftermarket. What do you think - is it good idea to buy and install them or there is no need? Would they help to prevent the rust?
Old 01-08-2009, 03:11 PM
H-T White Ops
NOFX's Avatar
I don't think they'd prevent rust. Water will still get in there and it might even sit along the edge, right under the liner.
It could protect the wheel well from chips though.
They might really help hatch owners with the famous taillight leaks. Perhaps you could link them?
Old 01-08-2009, 03:28 PM
zcar4me's Avatar
If you decide to buy new, don't get the cheap knock-off ones. I bought some from rockauto.com and each of them were about $8. I should've known better. Practically none of the holes matched up, and I had to trim in a few places. It made a 30 minute job, a 3 hour job.
If you buy new, get the oem honda pieces.
JoshuaVTEC
14
03-22-2015 06:11 AM
IntegraGSR1999
05-31-2009 04:43 PM
Paul*DC4
03-31-2007 07:08 PM
'90crxSI
09-04-2006 07:08 PM
PY2KITR1060
05-19-2002 07:25 PM
Quick Reply: inner fender liner???
