Injectors size question???
Old 02-15-2005, 03:11 AM
SLOAZZ95's Avatar
Default Injectors size question???
see sing for setup, i also have just bought a aem fuel rail. my questioj is will my stk injector work or should i step it up and replace them also. if i replace them what size should i step up tp. not a turbo app so i dont think i need dsm 440s. what are your suggestions?
Old 02-15-2005, 03:48 AM
Lmgrcivic's Avatar
Default Re: Injectors size question??? (SLOAZZ95)
you can use your stock ones but if you want to go bigger you could go with 310's or even 370's
Old 02-15-2005, 03:59 AM
SLOAZZ95's Avatar
Default Re: Injectors size question??? (Lmgrcivic)
what brand, rc, etc... and are they plug and play or will i need resistor box. i am looking for plug and play
Old 02-15-2005, 04:21 AM
92civicb18b1's Avatar
what size are the dsm non turbos...like 300 something right?
It just a cheap alterantive...but you have a few brands to choose from, cant remember them off the top of my head
Old 02-15-2005, 02:16 PM
Lmgrcivic's Avatar
heres a link for one of the injectors sales on here for RC thats a real good deal
https://honda-tech.com/zerothread?id=1014516
Old 02-15-2005, 02:17 PM
jlacoy82's Avatar
Just use the OEM Honda 240cc's from the d16y8, sir.
Old 02-15-2005, 03:22 PM
SOHCD16y8's Avatar
yeah i just bought some 550s from wiredricky in the classifieds section great deal
Old 02-16-2005, 05:36 PM
SLOAZZ95's Avatar
Default Re: (SOHCD16y8)
ok, here is another ? first off, my car is obd1 so how can y8 injectors work well with my vehicle seeing that they are obd2. also what is the difference between y8 and z6 injectors, they are both 240cc injectors. second, what is the point of upgrading your fuel system without have a air fuel controler. i mean your computer is what allows the fuel maps to change, not the parts you put on. i think? is this right. let me know, thanks.
Old 02-18-2005, 02:45 AM
SLOAZZ95's Avatar
Default Re: (SLOAZZ95)
ttt
Old 02-18-2005, 07:13 AM
shifty35's Avatar
The real question is, why do you need to upgrade your injectors? Unless you plan on going FI or N2O, your stock injectors will be FINE. Get an air fuel controller if you need to tweak a little, possibly increase your fuel pressure if you must.
Old 02-18-2005, 07:56 AM
eK9aT10pSi's Avatar
Default Re: Injectors size question??? (92civicb18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicb18b1 &raquo;</TD></TR><TR><TD CLASS="quote">what size are the dsm non turbos...like 300 something right?</TD></TR></TABLE>
390cc
Old 02-18-2005, 07:59 AM
dantastic's Avatar
Default Re: Injectors size question??? (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Just use the OEM Honda 240cc's from the d16y8, sir.</TD></TR></TABLE>
his EX already had oem honda 240's
you should be good to atleast 160whp with stock injectors.
Old 02-18-2005, 09:13 AM
EG6 SiR's Avatar
Default Re: Injectors size question??? (dantastic)
There is some good info on this other thread that someone started up.
https://honda-tech.com/zerothread?id=1151821
SmaTTeRLegion
06-18-2013 01:39 PM
Charlie Moua
10-28-2009 11:09 AM
carrnut21
11-30-2007 04:51 AM
Change
09-25-2004 08:24 PM
Quick Reply: Injectors size question???
