Injectors size question???
see sing for setup, i also have just bought a aem fuel rail. my questioj is will my stk injector work or should i step it up and replace them also. if i replace them what size should i step up tp. not a turbo app so i dont think i need dsm 440s. what are your suggestions?
Re: Injectors size question??? (Lmgrcivic)
what brand, rc, etc... and are they plug and play or will i need resistor box. i am looking for plug and play
Re: Injectors size question??? (SLOAZZ95)
what size are the dsm non turbos...like 300 something right?
It just a cheap alterantive...but you have a few brands to choose from, cant remember them off the top of my head
heres a link for one of the injectors sales on here for RC thats a real good deal
https://honda-tech.com/zerothread?id=1014516
Re: (SOHCD16y8)
ok, here is another ? first off, my car is obd1 so how can y8 injectors work well with my vehicle seeing that they are obd2. also what is the difference between y8 and z6 injectors, they are both 240cc injectors. second, what is the point of upgrading your fuel system without have a air fuel controler. i mean your computer is what allows the fuel maps to change, not the parts you put on. i think? is this right. let me know, thanks.
Re: (SLOAZZ95)
The real question is, why do you need to upgrade your injectors? Unless you plan on going FI or N2O, your stock injectors will be FINE. Get an air fuel controller if you need to tweak a little, possibly increase your fuel pressure if you must.
Re: Injectors size question??? (92civicb18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicb18b1 »</TD></TR><TR><TD CLASS="quote">what size are the dsm non turbos...like 300 something right?</TD></TR></TABLE>
390cc
390cc
Re: Injectors size question??? (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Just use the OEM Honda 240cc's from the d16y8, sir.</TD></TR></TABLE>
his EX already had oem honda 240's
you should be good to atleast 160whp with stock injectors.
Re: Injectors size question??? (dantastic)
There is some good info on this other thread that someone started up.
https://honda-tech.com/zerothread?id=1151821
