indiccator fault
indiccator fault
hi i have a 93 1.6 crx del sol. does anyone know where the relay is for my indicators as they are flashing quickly as if a bulb has gone but they are all working fine, also work normal on hazzards. i want to check relay first before i start getting more involded with wiring faults. i anyone has had a fault like this and has sorted please let me know, i have just brought it and there was both repeater bulbs out so i brought it and thought it was just bulbs but i was so wrong. thanks rachel
Re: indiccator fault
it is on the interior fuse box, it plugs into it, i think it is like on the top right, but if your not sure you have the right one just google the number on it and it will tell you what it is. Although normally i don't think a relay would fail like that usually it is all or nothing before you replace it you may want to try different bulbs normally blinking to fast is because you have the wrong bulbs.
Wrona
09-18-2011 07:27 AM
rickkane
11-29-2008 11:03 AM
