Idle Prob
Idle Prob
Got a tremendous idle problem, right after i start and the ecu ends its "open loop" per say it bounces idle like crazy even when im driving for a while, and sometimes it'll be perfect. but most of the time it would have a bounce to about 2500.
When i hit the clutch to shift i can tell its reving without the gas it sucks and super annoying anyone got any suggestions or had this problem?
Re: Idle Prob (civictildeath)
Negative only code is vss speed sensor. the idle is soooo annoying. cause when im at a light everyone thinks i want to race them LOL, then i see them take off then i spank them a mintue after i notice it.
Re: Idle Prob (conFusedEG)
in the services were you?? jk i had a similar prob in my 91 lx and i was told the iacv (idle air control vavle) was bad. dont know if that was it cause i sold it without fixing it. but it gives you something to check out
Bump, yeah I'm in the Air National Guard actually hehe yeah a friend thinks its a coolant problem but temp is prefect. Anyone else got similar problems with different cures?
Re: Idle Prob (99b18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99b18 »</TD></TR><TR><TD CLASS="quote">surging idle is commonly the cause of a vaccum leak. but it should do it all the time. not just once the o2 is reading.</TD></TR></TABLE>
Not true. Think of a condition, on a perfectly running, no-vaccum leak engine, where the instant you start the car, the idle is raised by the ECU??
Yep - cold start. So really, a vaccum leak is going to cause surge when the ECU thinks the engine has now warmed up - not when its cold.
Air bubbles in the coolant will also trick the ECT into thinking the coolant is cooler than what it is - this tells the ECU to re-activate the cold-start-up strategy and increase the idle till it thinks the engine warms up.
But with an idle rpm of 2500 - you are more than likely looking at a vaccum leak and not so much air in the coolant (but bleed it anyway to make sure - doesn't take but 10 minutes or so).
Re: (kihun_cha)
Yea, I had similiar problems and changed alot of things to try to find out what the problem was. it's either a vacumm leak, IACV, or your throttle body itself. I found out it was my bored out tb, no idea how..must be a leak at the butterfly. Mines jump from 1000-2000 back n forth and sure is freaking annoying. i even had a few morons rev'd at me because of it.
Re: Idle Prob (EE_Chris)
thanks for the great feed back, luckily i need a good tune up on the car, so im gonna replace all the radiator hosing anyways, cause i found a tiny leak on the feed hose, and im gonna check the control valve.
Thanks alot guys
Thanks alot guys
Re: (kihun_cha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kihun_cha »</TD></TR><TR><TD CLASS="quote">IACV</TD></TR></TABLE>
try unplugging it and see if it goes away. also, make sure your cooling system is well bled.
Nisif
11-26-2011 07:22 PM
supradrifter
12-19-2006 08:43 AM
