identify b16A sirII or sirI or what
Re: identify b16A sirII or sirI or what (xoutlawz00x)
im SURE this has been duscussed here before....
but here are some clues....
sir I = DOHC vtec
sir II =dohc VTEC (dead giveaway if the valve cover is origonal)
different color harness plugs, grey vs. some other color...
plaque on IM on 1st gen
sir I = DOHC vtec
1 Post
SiRI and SiRII were trim levels in various generations of the civic in Japan.they do not designate between different years of the motors.
you want to know how to distinguish pre OBD(88-91 US civic) motors from OBDI(92-95 US Civic)motors.
main things:
http://tech.hybridgarage.com/tech/b16/index.html
Chris
main things:
Chris
1 Post
Re: identify b16A sirII or sirI or what (rhdSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdSiR »</TD></TR><TR><TD CLASS="quote">he is refering to SiR II motors (1992 up vtec B16A's) to distinguish between SiR I (Pre 1992 vtec B16A's)</TD></TR></TABLE>
yes,i realize that.SiRI and SiRII DO NOT distinguish between different years of the motors.there are SiR and SiRII trim levels in both the EF and EG generations.
read the link-it lists many ways to tell the difference in the OBDI and pre-OBD B16s.
many people use the SiRI and SiRII titles to designate between the two generations of motors,but it's not accurate:
EF lineup:
http://www.honda.co.jp/HOT/Mod....html
EG lineup:
Chris
Modified by TeamNextGenChris at 4:26 AM 1/31/2005
EF lineup:
EG lineup:
Chris
Re: identify b16A sirII or sirI or what (TeamNextGenChris)
well the motor is out of the car and it has a gsr valve cover and the head says 1991.. is there any way esle i can tell the differnece
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x »</TD></TR><TR><TD CLASS="quote">well the motor is out of the car and it has a gsr valve cover and the head says 1991.. is there any way esle i can tell the differnece</TD></TR></TABLE>
look at the colors of the sensor connectors,as well as the intake manifold differences listed in the above link.
Chris
Chris
1991 is the first year of SIR2. Also it should only have 1 O2 sensor if it is a SIR2. All SIR2 come with hydralic trannys but this will not tell you the truth.
Re: identify b16A sirII or sirI or what (del_orson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson »</TD></TR><TR><TD CLASS="quote"> All SIR2 come with hydralic trannys but this will not tell you the truth.</TD></TR></TABLE>
not a true statement i have seen SiR-II with cable tranny's....i have one
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson »</TD></TR><TR><TD CLASS="quote">1991 is the first year of SIR2. Also it should only have 1 O2 sensor if it is a SIR2. All SIR2 come with hydralic trannys but this will not tell you the truth.</TD></TR></TABLE>
look at the links i provided.this is straight from the Honda of Japan website.there was an SiRII in the EF series,of which NONE have hydro trannies.also notice that each model has listed the year it debuted.the SiRII EF came out in 1989.
Chris
Chris
hondahead21
05-04-2008 04:52 AM
