Taking off the IACV? What to do?
Old Jul 13, 2003 | 06:04 PM
cnydelSolHybrid's Avatar
Default Taking off the IACV? What to do?
Ok, I have searched and no information helps me. SO here we are. I have no thermostat in my engine b/c i want the coolant to free flow to keep my temp 160-180. So I want to remove the iacv B/C it maked my idle irratic sometimes and its terrible. I know the Venom Has no Hook up for it so???
1 leave the iacv on and dont run the coolant lines to it?
2 take it off the manifold and TB and leave it open?
3 How can i make my ecu not toss the code???
Ok, thats all for now.. Thanks Guys
Old Jul 13, 2003 | 06:19 PM
93LSivic's Avatar
Default Re: Taking off the IACV? What to do? (cnydelSolHybrid)
I run my IAC external to my Venom intake. No need to run coolant lines through it, but just make an aluminum plate on the oring side and tap 2 fitting on it (i used air line barbed fittings---had them sitting around and they work) or weld if you have the option. Make both lines go on either side of the throttle plate and you should be ok.
Vagitarian
23
Oct 21, 2012 08:27 PM
jdmwojo
Jan 31, 2010 10:07 PM
lude98SH
Aug 12, 2007 07:49 PM
dinosa21
Nov 27, 2002 01:22 PM
X2BOARD
May 17, 2002 12:57 PM
