i need some help
i need some help
i have a 93 civic ex with a gsr motor the motor is good but the tranny is givin me a lil problem...the problem is when i step on it and try to change from 2 to 3 it grinds but it only happens when its at high rpms other then that when i drive normal it dont do it....
Re: i need some help (IMPORT_IMAGE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE »</TD></TR><TR><TD CLASS="quote">i have a 93 civic ex with a gsr motor the motor is good but the tranny is givin me a lil problem...the problem is when i step on it and try to change from 2 to 3 it grinds but it only happens when its at high rpms other then that when i drive normal it dont do it....</TD></TR></TABLE>
you can try changing your tranny fluid and see if that helps, but it sounds like your syncros are going bad.
Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">Buy a new tranny?</TD></TR></TABLE>
SHHH!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT_IMAGE »</TD></TR><TR><TD CLASS="quote">wut kind of fluid should i get ?</TD></TR></TABLE>
Honda's manual transmission fluid is the best, so stick with it.
SHHH!!!!
snatch
12-13-2005 11:23 AM
