i got question.. !!!?????
Old 02-17-2007, 04:17 PM
D15JDMARIO's Avatar
Default i got question.. !!!?????
I got a D15B swap running with the JDM computer .. im having problems with Code 3 MAP sensor!!! when car in on and i plug the map sensor In car shuts off.. when map sensor is not plug the car turns on and runs rich and stall.. i mean ive put 2 different map sensor and same.. please help help help!! thanks guys..
Old 02-17-2007, 04:23 PM
pdiggitydogg's Avatar
lets start with:
Are you sure you have your map and tps connectors in the right locations? Physically, they are the same...
Old 02-17-2007, 04:37 PM
D15JDMARIO's Avatar
Default Re: (pdiggitydogg)
yes sir i had to wire Map sensor st8r to the ECU.. cause the harness i have only had one plug and it was for the TPS.. so i wired the Map sensor with cable st8r from the computer to the sensor and still getting the same problem !!
Old 02-18-2007, 01:52 AM
Hairy Hudson's Avatar
Default Re: i got question.. !!!????? (D15JDMARIO)
For some reasion I'd be half tempted to check into you idle speed screw. I had a B16A in my EF and I remember having to tweek with it in order to connect all my sensors on the TB.
Good luck man
Randyb18
08-09-2015 03:07 PM
oksblue
03-31-2013 03:59 PM
attica
12
08-20-2009 08:43 AM
93dabeast
05-23-2007 04:24 AM
Hella_Fresh
10
04-05-2007 04:34 PM
Quick Reply: i got question.. !!!?????
