i got a 93 honda civic NEED HELP WITH THE KEY SWITCH
Old 07-04-2008, 11:36 PM
DJNauTicz's Avatar
Default i got a 93 honda civic NEED HELP WITH THE KEY SWITCH
recently my car got break in..and tat person damage my key switch
so my car can't start when i try to turn my key ( he removed all the screw's and stuff ) so i was wonder anyone out there have a DIY or any information on how to fix this problem please help thanks i can take pic if u guys need
Old 07-04-2008, 11:44 PM
riceburnerryan's Avatar
are you getting spark? and are you throwing any codes?
Old 07-05-2008, 05:45 AM
jdmdikk's Avatar
Default Re: (riceburnerryan)
try checking your main fuse up front ..it may be the battery fuse..you can check by seeing if anything else works like the battery for instance..you can also just go and get a switch at a junkyard and just get a key made or take your cylinder and place it on the new switch ..thats what i did when they stoled my girlfriends car..
Old 07-05-2008, 11:51 AM
DJNauTicz's Avatar
Default Re: i got a 93 honda civic NEED HELP WITH THE KEY SWITCH (DJNauTicz)
no spark's and anything wat happen was.the remove the key switch thing so is like hangin there.. is really hard to explain i'll post picture tonight..so you guys can understand the problem better..
Old 07-06-2008, 07:33 PM
kr0nic1's Avatar
happened to me i have to start it with a screw driver the key thing wont work even when i screw the starter piece i put the screw driver into...so i just use the screw driver
Marisa11
Honda Civic (2006 - 2015)
09-25-2018 12:13 PM
h2oiamwater
11-26-2016 12:48 AM
slq576
11-19-2013 07:50 PM
KleanEj1
13
12-30-2009 02:43 PM
bannacrx
07-07-2008 12:08 PM
Quick Reply: i got a 93 honda civic NEED HELP WITH THE KEY SWITCH
