I don't have a rev limiter? Info. needed...
Old 04-25-2004, 11:38 AM
BlackCivSi's Avatar
Default I don't have a rev limiter? Info. needed...
I haven't raced in the 1/4mile in a while, so I did and noticed my 2000si doesn't have a rev limiter any more? What could have happened? Is it something with the ECU? I can use all the feedback....
Old 04-25-2004, 11:41 AM
Filliam H. Muffman's Avatar
Default Re: I don't have a rev limiter? Info. needed... (PNelsonBLKSi)
...how high have you revved it?
Old 04-25-2004, 11:44 AM
BlackCivSi's Avatar
Default Re: I don't have a rev limiter? Info. needed... (JUN EK9)
I found out my accident, where the rev limiter was supposed to kick in, but the rpm's jumped to about 8900 - 9000
Old 04-25-2004, 11:50 AM
jerbear!'s Avatar
tach's are off. my rev limit is supposed to kick in at 6500 but i goes all teh way to 7200 til it kicks in
Old 04-25-2004, 11:51 AM
MarkZeroNine's Avatar
lol.. wow.
my old hatch w/ a b16a2 didnt have a rev-limiter because it was a kenji chipped ecu, scared the hell outta me..
dont know what to tell you though sorry
Old 04-25-2004, 11:52 AM
eL
eL's Avatar
Default Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">tach's are off. my rev limit is supposed to kick in at 6500 but i goes all teh way to 7200 til it kicks in</TD></TR></TABLE>
what are you running with a 6500 limit?
Old 04-25-2004, 11:54 AM
Default Re: (eL)
did it stop revving after 9k or did you let off?
BlackCivSi's Avatar
Default Re: I don't have a rev limiter? Info. needed... (HondaSellout)
I have the B-16a2, do you think it has a chip in it then, I did buy it used, but it never did this before, and Ive had it fo aboiut a year now? It scared the hell out of me too... Damn, I don't know what to do...
Old 04-25-2004, 11:59 AM
Global Moderator
Jimmy's Avatar
You have no ******* clue what your talking about.
Hint that he said 99-00 si and anyways the p28 doesnt even rev limit at 6500 rpms anyways.
Heres a little sneak peak of some of the new rules..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guidelines &raquo;</TD></TR><TR><TD CLASS="quote">
11. If you are going to post some information and are not 100% sure if it is correct, then please say so.
If there is a tech topic and you have a "pretty good idea" about an answer then please say so. Stating something matter-of-factly when you're not 100% certain can be a terrible thing. Also sometimes you may think you have the right info, so try to avoid posting things in a manner that leaves you no wiggle room if it ends up being incorrect. Use phrases like "I'm pety sure" or "If I recall correctly" so that someone else can verify your info before someone else takes it as gosphel truth.
Old 04-25-2004, 12:01 PM
Luserkid's Avatar
Default Re: (Usdmdc2)
I think jerbear was just giving a example of tachs being off. Because he said nothing about ecu's or anything with the SI. Just that tachs are off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">
what are you running with a 6500 limit?</TD></TR></TABLE>
Im thinking D15? Thats where my limit was at anyway.
Old 04-25-2004, 12:02 PM
Mr.E.G.'s Avatar
maybe jerbear has an ls. he didnt say that his b-16 ecu has a rev limiter that kicks in late. he just said that his rev limiter is supposed to kick in at x rpms and is late to the show. i have a b-20 and an ls ecu and the rev limiter kicks in some where around 7200.
Old 04-25-2004, 12:05 PM
wtf..dc2 what the hell are you talking about?. nobody said anything about a p28, and the stock tachs are off at the higher RPM range, but i dont know if thats the problem
EDIT: i believe VX's cut off around 6500.(notsure)
Old 04-27-2004, 08:36 PM
BlackCivSi's Avatar
When my tach reached 9000 I let off. I tried it tonight just to see, damn, I don't have money to take it somewhere and have it looked at, does anyone have anymore info. about my 2000si that doesn't seem to have a rev limiter???
Old 04-27-2004, 08:40 PM
dantastic's Avatar
my eh2 tach goes to 9000, then hits the revlimiter (p28 chipped to p30 spec, 8500 rpms rev limit). damn inaccurate honda tachs
Old 04-27-2004, 09:55 PM
EG-B20vtec's Avatar
Default Re: (dantastic)
Who cares?
Those wack stock cams ain't doing nothing after 8000 rpm.
So shift already!
Old 05-01-2004, 09:34 AM
BlackCivSi's Avatar
Default Re: (EG-B20vtec)
Not running stock cams...Running Skunk 2 Stage 1 cams...I still shift before 8 anyways...Those cams sure make my vtec scream though...
Old 05-01-2004, 10:03 AM
a/k/a Jomo
Mr Hammond's Avatar
Default Re: (BlackCivSi)
Have you even looked at your ECU to see if you still have a P2T ECU???
Old 05-01-2004, 10:43 AM
Lil Corb's Avatar
do you have a v-afc or another way to see the RPMs accuratly? cause stock tachs suck at high rpms. I have a em1 too and I took it too 8500 and it still didn't hit fuel cut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCivSi &raquo;</TD></TR><TR><TD CLASS="quote">Not running stock cams...Running Skunk 2 Stage 1 cams...I still shift before 8 anyways...Those cams sure make my vtec scream though...</TD></TR></TABLE>
What kind of valvetrain do you have?
Old 05-02-2004, 03:23 PM
krys's Avatar
ok well if you keep doing that your going to get valve float that is if you dont have stock int but you can all way just pick up a new ecu for like 250 or so at inlinefour.com
Old 05-03-2004, 02:05 PM
BlackCivSi's Avatar
Default Re: (krys)
Ya, so I had someone look at my **** and they said my ECU was chipped with something they never seen before. I'm going to have to buy a new one now, anyone got ideas about which one would do me best?
Old 05-03-2004, 05:08 PM
a/k/a Jomo
Mr Hammond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCivSi &raquo;</TD></TR><TR><TD CLASS="quote">Ya, so I had someone look at my **** and they said my ECU was chipped with something they never seen before. I'm going to have to buy a new one now, anyone got ideas about which one would do me best?</TD></TR></TABLE>
Well if you want a stock ECU I have a 99-00 civic Si ECU. If you want to convert to OBD1. PM Kenji.
Old 05-04-2004, 08:24 PM
BlackCivSi's Avatar
Default Re: (Mr Milano)
thanks for the offer, but i already got one from a pick and pull, if it doesn't work out i'll be sure to start another thread...
severaltony
03-15-2012 11:23 PM
KDvtec5757
07-01-2008 07:30 AM
fandirabbani08
Honda Civic (2006 - 2015)
02-16-2007 12:47 PM
Singlecam4dr
01-27-2007 11:50 AM
bruce-si
01-21-2006 09:31 PM
Quick Reply: I don't have a rev limiter? Info. needed...
