how too
you should wait about 30mins... i just did this 3 days ago.. talked with the people at honda.. and they say.. if you just pop the neg. off and on real quick and can **** up the ecu fuse. soo just pop it off for 30mins.. put it back on... crank up the car and it should be good to go
Re: (sd.coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe »</TD></TR><TR><TD CLASS="quote">you should wait about 30mins... i just did this 3 days ago.. talked with the people at honda.. and they say.. if you just pop the neg. off and on real quick and can **** up the ecu fuse. soo just pop it off for 30mins.. put it back on... crank up the car and it should be good to go</TD></TR></TABLE>
Thanks for that info. Mabe my random, non-storing CEL will finally go away.
well it was throwing 2 long flashes and 5 short flashes thanks guys for the help i would buy you guys lunch but it would rottten by the time it get there ahahah j/j cause i live hawaii yo but thanks again guys big *** help alohas
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (jdmsoljah)
That would be a code 25, long flashes are 10's and short are 1's. Just add em up. Oh and you don't need to remove the battery terminal for 30 minutes or even 5 minutes. Just remove the 15a fuse under-hood for 20-30SECONDS and your ECU is reset.
Re: (jdmsoljah)
I think this will help you:
http://www.albinoblacksheep.com/flash/posting.php
Moral of the Flash presentation: Read the stickies at the top of the page.
Re: (fakemike)
To reset the ECU, take both terminals off the battery, then touch them together. It will completely drain all power from the system and reset. This was directly from a Honda tech, and it works.
Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">To reset the ECU, take both terminals off the battery, then touch them together. It will completely drain all power from the system and reset. This was directly from a Honda tech, and it works.
Very unsafe to be handling the positive and negative at the same time. You do not want to be in the middle of a circuit. It would be easier to just unplug the negative for a few seconds and not mess with the positive at all.
An easy way for me to do this without having to reset my cd player's memory is to unplug the connectors from the ecu itself and wait a few seconds and plug them back in. Takes a minute for me.
Re: (wadup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wadup »</TD></TR><TR><TD CLASS="quote">
Your not in the middle of a circuit, you take both leads off the battery, eliminating the power source. It'd be doing the same thing as touching two leads together that aren't connected to anything.
What you're doing is draining any power left by the capacitance in the system which could be saving any codes.
Re: (fakemike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike »</TD></TR><TR><TD CLASS="quote">I think this will help you:
Moral of the Flash presentation: Read the stickies at the top of the page.</TD></TR></TABLE>
lol
lol
stream2004
04-01-2004 08:53 AM
