how tight do you tighten you acc belts?
Old 07-05-2005, 07:20 PM
igo4bmx's Avatar
Default how tight do you tighten you acc belts?
im not sure how tight i can make the belts go safely
Old 07-05-2005, 07:22 PM
Electrician
Deemeetree's Avatar
Tighten the belts until there is some play in it. If you can't even budge it a millimeter, it's WAY too tight. If there is some play in it when you push and pull it, but not enough to make it "jump" or essentially vibrate off on hard accelerations, you're good to go.
What belts did you need? I'll check my Helms for exact specifications.
Old 07-05-2005, 07:24 PM
igo4bmx's Avatar
Default Re: (Deemeetree)
i just messed with the power steering belt... it was uber tight...
i loosened it a bit so it has some play (according to the helms 1/4 deflection) and now it screeches like crazy
Old 07-05-2005, 07:53 PM
Electrician
Deemeetree's Avatar
Does the belt show any signs of wear and tear? Why DID you loosen the belt? Probably, after miles and miles of use at that tension, it might of stretched a bit from OEM-spec and conformed to it.
Now that it's loose, it won't return to it's original size, and will screech.
Have you changed it out with a non-OEM unit or if you have, does it have the same rib-pattern?
Old 07-05-2005, 08:09 PM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Does the belt show any signs of wear and tear? Why DID you loosen the belt? Probably, after miles and miles of use at that tension, it might of stretched a bit from OEM-spec and conformed to it.
Have you changed it out with a non-OEM unit or if you have, does it have the same rib-pattern?</TD></TR></TABLE>
i figured out the main proble
alt belt is loose
im running a HO alternator from http://www.4alterstart.com and the pulley is smaller than stock... using a stock belt tension was ok but the adjustment bolt was maxed out...
im gonna replace it with a belt thats 1 inch short than stock...
i hope autozone/ pep boys has something
Old 07-05-2005, 08:19 PM
Electrician
Deemeetree's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">i figured out the main proble
alt belt is loose
i hope autozone/ pep boys has something</TD></TR></TABLE>
Make sure it has the same amount of ribs on it. Easiest way is to get all their assortment of the belts on the counter, search and pick from the litter.
Old 07-05-2005, 08:22 PM
igo4bmx's Avatar
anyone know the stock alternator belt length?
it would be a pain to get my belt off, get a ride from someone to the auto store, then drive back and put it on....
the problem is i'm running ahigh output alt and need a shorter than stock belt
Old 07-05-2005, 08:25 PM
Electrician
Deemeetree's Avatar
Ask for the stock belt for that engine. Then, look at the other ones and compare it to the stock one. For the most part, it will be equal in length to an OEM-Honda one.
Old 07-05-2005, 08:29 PM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Ask for the stock belt for that engine. Then, look at the other ones and compare it to the stock one. For the most part, it will be equal in length to an OEM-Honda one.</TD></TR></TABLE>
good idea!
turbotime
05-27-2006 04:54 PM
speedtrash
01-16-2006 07:06 PM
Philip
02-23-2004 08:36 AM
Soy Bean
02-02-2004 09:50 PM
sfr4dr
02-12-2003 01:06 PM
Quick Reply: how tight do you tighten you acc belts?
