How much boost/max horse? gt28 turbo?300hp?
How much boost/max horse? gt28 turbo?300hp?internally gated
I was wondering if anyone knew how much boost i could run on my low compression turbo setup, its a garett t28 with an internal wastegate and also if my intercooler would hold that much power............? (its the turbo and intercooler from the edelbrock turbo kit) thanks
heres a link to the it
http://www.edelbrock.com/sport...shtml
Modified by MBlake55 at 4:45 PM 3/12/2007
Re: How much boost/max horse? gt28 turbo?300hp? (MBlake55)
uhhh.....engine? mods? i'm assuming stock d-series for the time being. with a good tune, 200whp is achievable. I personally would run 180-190whp just to be on the safe side.
Re: How much boost/max horse? gt28 turbo?300hp? (Nongan)
sry ya that would help, im building the motor,hot tank,hone cylinders,grind crank, and im wonderin how much after the build i could achieve
-bottom end
with wiseco pistons,eagle rods,acl bearings
-Head
dsm 450 injectors
stock cam,new valve springs
-bottom end
-Head
dsm 450 injectors
-bottom end
-Head
dsm 450 injectors
stock cam,new valve springs WHEN DO DSM 450cc INJECTORS MAX OUT?
-bottom end
-Head
dsm 450 injectors
take it to a good tuner, he should be able to tell you. my bet would be 250-300whp would be safe if you have the following:
forged pistons/rods
arp rod bolts
new bearings
sleeved block
head work is useful for a better power band and to reduce valve float at high rpm's, but stock d series heads have seen 300whp before no problem.
forged pistons/rods
arp rod bolts
new bearings
sleeved block
k thanks ya im going to be getting better/stronger valve springs tho so i dont get valve float........anyone else have any comments? suggestions?
sleeves arent completely necessary, stock sleeves are rated around 400hp+ i believe...
which t-28? theres different trims and whatnot. as i understand the one that comes with the edelbrock kit tops out at 250ish? im pretty sure but not positive. oh and you will be limited by the internal wastegate
Re: How much boost/max horse? gt28 turbo?300hp? (hatchnideas)
sleeves may not be necessary, but you'll sure be wishing you had em if your engine blows. my advice is to upgrade valvetrain, new cam (exospeed or crower), do the block work, stick the turbo in there and tune it to 250-300whp
