things i can do to make another 20whp?
Old Jun 26, 2003 | 08:58 PM
xXx Justin xXx's Avatar
Default things i can do to make another 20whp?
ok read my signature... thats a pretty good sum of what i am running. what would be the easiest... (cheapest) way to make another 20whp.... and please, nobody say nawwzzzzzz... however it is spelled in the ricer lingo...thanks
Old Jun 26, 2003 | 08:59 PM
lazerus's Avatar
Default Re: things i can do to make another 20whp? (SOHC Beast)
hmmmm... 2 more psi? not sure if you can think about that on a d16z6 though
Old Jun 26, 2003 | 09:01 PM
paulzy's Avatar
Default Re: things i can do to make another 20whp? (lazerus)
I would have to say bump up the boost also...or Nitrous
Old Jun 26, 2003 | 09:11 PM
CivicSoul's Avatar
Default Re: things i can do to make another 20whp? (Paul_Vang)
bigger turbo, bigger intercooler, lovefab manifold, nothing is cheap. More boost is the easiest but not cheapest.
Old Jun 26, 2003 | 09:17 PM
Drew Peacock's Avatar
Default Re: things i can do to make another 20whp? (CivicSoul)
2 more psi and race gas if your rods snap its your problem its the risk you have to take.
Old Jun 26, 2003 | 09:52 PM
MiraiZ's Avatar
Default Re: things i can do to make another 20whp? (turbozxi)
same psi, bigger turbo, bigger injectors..
Old Jun 26, 2003 | 10:04 PM
Fired Honda's Avatar
Run 550 injector ..what Comp ratio?...if low, then crank up the boost..Well In my opion D motor are not ment for boost..
anyways, 20whp haa?? Do some weight reduction, hood, empty trunks, do what ever take out at lease about 70 then you gain some power there, then crank up 1 or 2 boost then there you go..
Like everyone said..cranks up the boost. and I think 450 injector is fine for up to 20psi i think..And also do you have a 255 fuel pump..?
That help out too...Change the boost timing?? upgrade cluth??..bigger IC?? little bigger turbo?? ..Wow, you can gain about 50whp if you did all of that correctly and tune it good..
Old Jun 26, 2003 | 10:38 PM
swrdply400mrelay's Avatar
Not sure if this will do 20hp, but you can try an intake manifold, or Crower turbo cam.
Old Jun 27, 2003 | 01:32 PM
Default Re: things i can do to make another 20whp? (swrdply400mrelay)
well i thought about a FMIC (my smic is getting like no air... only air is coming off of the tire.) get rid of my 2" DP that is dented in and have a 2.5" DP made. getting a walboro 255l fuel pump...2" turbo to IC pipe.... 2.25" ic to thorottle body pipes. and then if that didnt help.... maybe add a cam and cam gear then make vtec come in a little sooner...re-tune... i think all of that should make a pretty noticable difference.
but one thing i want to change is the spool time. . it doesnt reach 10psi til like 4200 or so. that sucks... it would have a lot more pull if it could spool faster....
what do you all think?
Old Jun 27, 2003 | 01:42 PM
JM Performance's Avatar
if you dont mine the lag thats gunna come w/ it...bigger turbo.
Old Jun 27, 2003 | 02:14 PM
ill_take_one's Avatar
Default Re: (Fired Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fired Honda &raquo;</TD></TR><TR><TD CLASS="quote">.Well In my opion D motor are not ment for boost..
Ah, great quote.
I'd just raise the boost up 2psi, or just get some rods/pistons then up the boost.
GL
Old Jun 27, 2003 | 02:26 PM
jinxproof99's Avatar
New User
motor swap.
Old Jun 27, 2003 | 02:32 PM
Default Re: things i can do to make another 20whp? (jinxproof99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 &raquo;</TD></TR><TR><TD CLASS="quote">motor swap. </TD></TR></TABLE>
phsstt.... no motor swap. this one just went in. i think i am going to get the front end straightened out on my 88 crx, put a dohc black top zc in it.... and have a weekend beater.... then maybe finish a few touches on my hatch, sell it and buy something luxurious? then again, maybe not?
Old Jun 28, 2003 | 01:03 PM
DeezNutts's Avatar
Sell the SOHC, buy a real motor with a BIG turbo, then you could make 200 more whp instead of 20
Old Jun 28, 2003 | 01:10 PM
Broken Gearbox's Avatar
Default Re: (DeezNutts)
well obvisouly the cheapest way to get 20hp more is too turn up the boost...but i guess you could get a FMIC,Bigger DP, D16Y8 Intake Manifold
Old Jun 28, 2003 | 02:57 PM
turbotime's Avatar
hey man, just put in some new rods and pistons and crank that up to like 20+psi. Then just hold on to your hat. My buddy has a turboed d16y8, built and he runs 25psi and KILLS ALL.
Old Jun 28, 2003 | 06:15 PM
DSF's Avatar
DSF
Like everyone else has said...
bigger DP
bigger turbo
fmic
more fuel
Isn't 4200 kinda high for full boost on the stock Greddy turbo? I thought they were really small.
Old Jun 28, 2003 | 08:32 PM
redline201's Avatar
Default Re: things i can do to make another 20whp? (DSF)
get the piston and rod combo from turbopanda
then up the boost
Old Jun 29, 2003 | 12:54 PM
Default Re: things i can do to make another 20whp? (redline201)
yea. it is a t25 turbo.. small as hell, but spools slow? i wish i could make it spool faster. and i am not replacing rods and pistons... im not tearing back into the engine. 450cc injectors should be fine.... but im not worried about it anymore.. probably selling it anyway.
Old Jun 29, 2003 | 01:54 PM
KTeller8's Avatar
Just change your sig. Boom now your 220whp
Old Jun 29, 2003 | 02:13 PM
TurboSedan's Avatar
New User
Default Re: (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">Just change your sig. Boom now your 220whp </TD></TR></TABLE>
Word, nuttin wrong with a little embellishing LOL
Old Jun 29, 2003 | 02:48 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fired Honda &raquo;</TD></TR><TR><TD CLASS="quote">Run 550 injector ..what Comp ratio?...if low, then crank up the boost..Well In my opion D motor are not ment for boost..
That help out too...Change the boost timing?? upgrade cluth??..bigger IC?? little bigger turbo?? ..Wow, you can gain about 50whp if you did all of that correctly and tune it good..</TD></TR></TABLE>
You sir, are retarded. It is alright to know nothing, but don't pretend it's something. You are correct that D-series engines were not meant to be boosted, but then again, neither was ANY Honda engine (sans the Turbo City engine from the 80's and the SC'd JDM Integra that never went into production)...weight reduction does not net power, it makes more effective use of power because the car is lighter, are you suggesting to remove the hood, ricer? I hope not, though it would be 2F, 2F (bling!)...Still awake, man? 450cc injectors are not sufficient for 20psi. You would be running mad rail pressure at that point and maxing out dutycycle. I would not run less than 550cc at that point, though it could be done with 450's, you would be asking for trouble. Change the boost timing? what are you trying to say here; "advance the ignition timing?" Well, I would assume he is running fairly advanced timing, but THIS is a possibility. I will give you that. However, upgrading the clutch?! The man didn't say; "Hey, my clutch is slipping, how can I make another 20whp and have it be completely useless because I'm retarded?"
Otherwise, you just listed a bunch of **** that everyong else did. christ. I am just getting annoyed with the circles of BS on this board...can we make some progress?!
But, I digress...I would say get rid of that wack 2" downpipe, you could also get an electric exhaust cut-out (significant gains have been seen even over full 3" systems, though mostly torque and spool-up) and the larger intercooler could gain you 10+hp. Also, the o2 housing on the Greddy kit is a little tweaked, since it allows for a/c, but there's no way around that without drastic changes.
I hope no one hates me for ranting there, but I felt it needed to be done
Old Jun 29, 2003 | 04:59 PM
ScrapinSi's Avatar
What about a co2 or n2o intercooler sprayer?
Old Jun 29, 2003 | 05:13 PM
boosted92's Avatar
Default Re: things i can do to make another 20whp? (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">What about a co2 or n2o intercooler sprayer? </TD></TR></TABLE>
He should spend his money on a real IC first
If you have a dremel, P&P the head and intake and port match them, then go for a good FMIC, and up the boost 1-2 pounds.
rdeezy78
Aug 27, 2007 03:19 PM
rollagti
Oct 22, 2006 06:03 AM
93TurboSi
Oct 16, 2003 06:04 PM
LOwrestling2001
Sep 4, 2002 10:54 AM
austrian type-R
Sep 26, 2001 08:00 PM
