How to identify a d16z6 head.
im making a purchase (for a hell of a good price) on a z6 head and i just need some help making sure i can distinguish it well before buying it, because i dont wanna end up with a vtec-e or someshit. any tips anyone? thanks.
Re: How to identify a d16z6 head. (mizzoEG)
well i got the d16z6 head, the guy exclaimed it came from a 95 civic si but the valve cover doesn't say vtec. anyone have any info why? hows does it look? thanks
My 1992 civic si valve cover looked exactly like that. They made the D16Z6 vtec motors for a while don't know how many years or what but I know it was in the early run of the 92-95 generation where they didn't say vtec on the valve covers. You can tell that the head is vtec two ways though, 1992-1995 vtec heads obviously have the vtec solenoid which is the thing sticking off the front right side of the head with a green plug coming out of it on the second picture. The other way to identify it is the placement of the spark plug wires. The plug wires go into the front of the valve cover on vtec motors and are 1.6L. All other sohc motors from 92-95 are 1.5L and the spark plug wires go in toward the back of the valve cover.
Re: (Hondacivic90ed)
thanks Hondacivic90ed, i think you're right because i've noticed the VTEC logo only on the late vtec model valve covers.
another question though, how much $ can someone estimate this head to be as seen in the pictures (its got about 80k on it)? thanks
Re: (mizzoEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG »</TD></TR><TR><TD CLASS="quote">thanks Hondacivic90ed, i think you're right because i've noticed the VTEC logo only on the late vtec model valve covers.
another question though, how much $ can someone estimate this head to be as seen in the pictures (its got about 80k on it)? thanks</TD></TR></TABLE>
i have seen them go for 150 - 300 depending on mileage.
it is definately a z6 head
looks to be in good condition.
one thing you should do to check the condition. turn the head upside down, put cyl 1 at TDC, make sure there is a spark plug in it (to seal the hole)
then pur oil in around the valves (fill it up to the top)
wait for a bit and see if any oil leaks past the valves and out the intake or exhaust ports.
if no oil leaks past, or very very little after it sits for a while then you know the valves are sealing correctly. do this to every one, you can do cyl 1 and 4 at the same time, and cyl 2 and 3 at the same time
also check and see if it is warped or not with a machined straight edge, if its warped it needs to be milled so the headgasket will seal.
i would do those things before using it, to save yourself some time and headache if something is fucked up
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondacivic90ed »</TD></TR><TR><TD CLASS="quote">My 1992 civic si valve cover looked exactly like that. They made the D16Z6 vtec motors for a while don't know how many years or what but I know it was in the early run of the 92-95 generation where they didn't say vtec on the valve covers. You can tell that the head is vtec two ways though, 1992-1995 vtec heads obviously have the vtec solenoid which is the thing sticking off the front right side of the head with a green plug coming out of it on the second picture. The other way to identify it is the placement of the spark plug wires. The plug wires go into the front of the valve cover on vtec motors and are 1.6L. All other sohc motors from 92-95 are 1.5L and the spark plug wires go in toward the back of the valve cover.</TD></TR></TABLE>
My ex-girlfriends car was a 94' Civic EX and it has a d16z6 with vtec written on the valve cover.
Re: (egsleepercivic)
right now im just in the process of finding a distributor and ecu for the mini swap.
i was just wondering how much overall power will i have after all is done?
1994 stock dx eg hatch w/ d15b7 102hp auto
after mini-me and intake?
Re: (vtecpoweredsol)
..i know that, just had another question which i stated earlier. didn't want to start a whole other thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG »</TD></TR><TR><TD CLASS="quote">right now im just in the process of finding a distributor and ecu for the mini swap.
after mini-me and intake? </TD></TR></TABLE>
1 Post
Re: (foowitdaredek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foowitdaredek »</TD></TR><TR><TD CLASS="quote">correct me if im wrong....the z6 has 125 hp so your basically bolting on 20-25 hp...</TD></TR></TABLE>
ok i will, ur wrong
Z6 comes out at around 90-110 on average... and the way you can tell is because theres a circular block stamp on ur head...
ok i will, ur wrong
there is a stamped code on the side of the head between the 3rd and 4th exhaust ports neerer the vc gasket. i think there was a thread not too long ago that decoded all of these. it's the only true gaurentee that it's a z6, or anything else for that reason.
Re: (JDM_SOHC)
not sure i understood correctly, lemmie ask again
How much hp/tq can this setup put out:
d15b7 block
d16z6 vtec head
k&n cold air intake
ngk iridium ix sparks
d16 intake manifold
aftermarket header
2.5 exhaust
just wanted an estimate thanks.
Modified by mizzoEG at 1:39 AM 10/10/2007
d15b7 block
d16z6 vtec head
k&n cold air intake
d16 intake manifold
aftermarket header
2.5 exhaust
Re: (mizzoEG)
the best way to get a clear answer backed by numbers is to check out the all motor forum and look through some dyno threads to find guys with similar setups. otherwise my guess or anyones is as good as yours
chinochanginc
06-28-2009 08:39 PM
