how hard is it to swap Dx doors to Ex doors
i was wondering how hard it is to change from manual doors to electric doors, like do you have to change the wire harness in the dash and ****. so any help would be appreciative thanks.
[Modified by ek9beyatch, 10:26 PM 1/4/2003]
Yar!
Re: how hard is it to swap Dx doors to Ex doors (ek9beyatch)
If you just want the ability to open your doors with a remote, just install door actuators (about $10 per door. You can find them on eBay), and run the relays to the module that will open/lock the doors (like an alarm). An illustration of installing actuators can be found here: http://www.a1electric.com/door_locks.htm
Re: how hard is it to swap Dx doors to Ex doors (Skuld)
If it is the power windows etc. that you are looking to get than you will have to either swap the complete door, then have them painted or you can swap all the internals. The door shells are identical(I know because my father hit my car in the driveway and now I have to get a complete shell from the dealer) The wiring should already exist in your factory molex plug. I believe you will have to install fuses in the empty locations on your fuse box. Good Luck.
Re: how hard is it to swap Dx doors to Ex doors (qcoffey)
remember if you are planning to add the power windows, you need to get a door panel in which it has the power window switches. I put power windows and door locks in my hatch, and i pretty much hardwired all of it, i used ex door panels, and then later ctr. Its not too much work, to get all of those creature comforts
Re: how hard is it to swap Dx doors to Ex doors (beeseries)
ok this is how it is i already have the doors from a 99 si and there the same color as my hatch so i was wondering if the wiring is hard or not. sorry i didnt say i had the doors before. all im really wondering is are the plugs already there or do i have to swap dash harness's
T Rick
10-03-2006 03:35 PM
