how excatly would i do this?
whats up..i just got some raybrig foglights of this stupid kid..he has a delsol and got pissed at all of the stupid ish on his car(rice) including a set of yellow raybrig foglights which he gave to me because he was just gonna throw them away(like i said he is stupid and dosnt know they are 170 bucks new so i said ill take em....
how would i wire these up to a switch? i know i ground the black wires to the chassis but how would i run the positive wire to the battery and a switch?..i want to be able to flip the switch on anytime i want car on or off..thanks
Re: how excatly would i do this? (Touge Panda)
buy a switch..put it where you want..plug the red wire(i'm assuming it's red from the foglight) then you can ground the ground wire to the ground anywhere...as far as that go..run the red wire from the foglight to the switch..then run another "LIVE" wire to the switch..make sure you put a fuse..just incase anything short out.. ..if you need any farther help..post up..
If you want them to come on weather the car is on or off then run a wire to the battery and ground the black wire to the chassis. But make sure to put a fuse on the power wire from the battery(close to the battery). If you want them to turn on with your park/head lights then run a relay off the park/head lights and wire accordingly. I would use the park/head lights cause it makes it a cleaner install(no aftermarket switches in the inside) and its easier to remember to turn them off.
red1997civic
12-25-2003 12:50 PM
LuderX
01-13-2003 05:49 PM
